Set map options for apps
ArcGIS includes ready-to-use apps that you can use to view maps in web browsers, mobile devices, and desktop map viewers. Some of these apps have configurable capabilities that you can show or hide based on the map. These capabilities include tracking, finding places and addresses, and finding features within a layer. As the map author, you set these as application properties on the item page of the map.
Create and save a map in Map Viewer.
Tip:
If you're using ArcGIS Collector on Windows or a map enabled for editing in ArcGIS Field Maps, the map must include at least one editable feature layer.
On the My content tab of the content page, click the name of the map to view its item page.
Click the Settings tab, and scroll down to the Application settings section under Web map.
Select the settings to enable.
Enable Search—Allows users to find features in a layer, records in a table, or addresses in the map.
Configure search options to enable search capabilities in apps that use the map.
Searching layers is supported in Map Viewer and most other apps that allow users to search in maps. Searching records in tables is currently only supported in apps built with ArcGIS Maps SDKs.
Searching for addresses in the map is supported by default in Map Viewer and most apps, regardless of whether By Address is selected. For some ArcGIS apps, searching by address can be disabled by unchecking the By Address check box. To determine whether disabling the By Address search option is supported in a specific ArcGIS app, refer to the app documentation.
Location sharing—Allows users to track mobile workers.
This is supported in maps that contain a hosted feature layer created from the Location Tracking template. To specify how often the location of the mobile worker will be recorded, select a time frame for tracking from the drop-down menu.
Use in ArcGIS Collector—Allows mobile workers to view a map with editable layers in ArcGIS Collector on Windows. Uncheck this check box to hide the map in Collector on Windows.
The Use in ArcGIS Collector check box must be enabled to collect data with maps enabled for editing in ArcGIS Field Maps.
Use in ArcGIS Field Maps—Allows mobile workers to view a map with editable layers in the ArcGIS Field Maps mobile app. Uncheck this check box to hide the map in the ArcGIS Field Maps mobile app.
Click Save to update the map with the enabled settings.
