Publish hosted feature layers
As a publisher in your organization, you can host feature data in ArcGIS Online by publishing hosted feature layers. ArcGIS Online supports multiple sources to allow you to accomplish this. You can upload the file types listed below to publish their contents, use a template or existing feature layer or collection, or publish from content in another app.
Comma-separated values (CSV) file (
.csv)Microsoft Excel file (
.xlsxor.xls)Shapefile (zipped)
GeoJSON file
File geodatabase (zipped)
Georeferenced photos (zipped)
Google Sheets on Google Drive
You can also define a blank hosted feature layer and the empty layers it contains. After the hosted feature layer is created, add fields to each layer.
Feature layers are useful when you need to expose vector data for display, query, and editing on the web or when you want to share a table of nonspatial attributes. Hosting a feature layer on ArcGIS Online is one way to share data with an internet audience if your own ArcGIS Server site cannot be made public. Maps, apps, and desktop map viewers can access your services from anywhere on the internet if you choose to allow it.
Feature layers are most appropriate for operational layers—the layers with which you interact—that go on top of reference layers, such as a basemap. For example, a feature layer may contain information about the street signs in your neighborhood. Each feature (street sign) may include the sign name, date installed, and a website URL for reporting problems to your local street department.
When publishing from a file or a feature collection, ArcGIS Online automatically sets the optimal visible range based on the data. When publishing a map from ArcGIS Pro, ArcGIS Online honors the existing scale range configured during the authoring process. When you create an empty hosted feature layer, it inherits the visible range of the feature layer or template you used to create it. To change the scale visibility of the hosted feature layer, open the layer in Map Viewer and set the visible range.
To complete the steps in the sections below, you must have privileges to publish hosted feature layers and create, update, and delete content.
Publish a .csv file
To web enable feature layers from .csv files, you upload them to ArcGIS Online and have them hosted as services. These services are referred to as hosted feature layers. This is a useful workflow if you do not have any ArcGIS products installed locally.
The steps below outline how to publish features or tables from ArcGIS Online using a .csv file.
To improve loading and publishing performance, ArcGIS Online reads the values in the first 10 rows of the .csv file to determine the data type and length to display for each field in the New item window. Any string fields with a length less than 256 will be increased to a length of 256 in the hosted feature layer. If any values on the field exceed 256, the length of the field in the hosted feature layer is increased.
Field names must meet the requirements of the database that ArcGIS Online uses to store the data. For information about column name limitations and reserved words, see the Microsoft SQL Server documentation.
These files do not enforce unique field names, but field names in hosted feature layers must be unique. Therefore, ensure all field names in your file are unique before publishing.
The features are published in the WGS 1984 Web Mercator (Auxiliary Sphere) coordinate system.
All fields in the file containing date and time values will be date or string fields in the published hosted feature layer.
The following steps explain how to add a .csv file from your local drive and publish. For instructions to access and publish a file from a cloud drive, see Publish from files on a cloud drive. For information about using a .csv file to create a feature layer as part of a reproducible process, see the ArcGIS Data Pipelines help.
Verify that you are signed in and that you have privileges to create, update, and delete content and publish hosted feature layers.
Open Content > My content, click New item, and click Your device.
Instead of clicking Your device and browsing to the file, you can drag the file onto the window from a file browser on your local machine.
If you do not click Your device or drag the file onto this window, you can click Feature layer and click Upload a file > Your device.
Find the file on your device or a machine on your network.
Select the file and click Open.
CSV files must be formatted and saved as
.csv.Choose Add <file name> and create a hosted layer or table.
Click Next.
Review the included fields and make changes as needed.
If the field types can be identified, they are set automatically. You can remove fields, change the display name of the field, and change the field type.
If the file contains one or more date fields, optionally choose a time zone from the Time Zone drop-down menu.
By default, date fields are assumed to be in the time zone of your browser. If your date fields store values that use a different time zone, choose that time zone. The time zone that you select is applied to all date fields in the file. If you later overwrite the hosted feature layer using updated data, the time zone specified when you initially published is used.
See Comma-separated values files for information about time zone considerations and supported date and time formats.
Tip:
You can configure pop-ups to display time.
Click Next.
Choose the information in the file that ArcGIS Online should use to locate features as follows:
If the file contains coordinates, choose Latitude and longitude, Military Grid Reference System (MGRS), or United States National Grid coordinates.
Choose Addresses or place names if the file contains place-names—for example, Westminster Abbey or Panama Canal—or addresses. By default, ArcGIS Online locates addresses based on your organization's region.
To create a nonspatial table layer, choose None.
If you are locating features based on an Addresses or place names value and your organization has multiple locators configured, click Advanced location settings, and choose the locator to use.
If the file contains addresses, click Advanced location settings, and use the Region drop-down list to specify the country in which the addresses are located. If the file contains addresses from multiple countries or from a country not in the list, select World.
By default, the locator adds a field that stores the coordinate location for each feature. You can include additional fields that provide information related to the geocoding process, such as how closely the location information in the input file matches with a location in the locator service.
Turn on the Enrich layer with address information toggle button, and choose one of the following options:
Append four fields that show how well addresses matched—Adds the following fields that describe the location and how well it matches information in the locator service:
status,score,match_addr, andaddr_type.Append 50 fields for full location information—Includes all available locator fields in the hosted feature layer.
For a description of all the fields that are added, see Geocoding and geosearch.
Choose whether the location information is based on one or multiple fields.
Click Next.
Provide a title.
Choose a folder in My content where you want to save the item.
Alternatively, you can choose Create new folder from the menu and provide a folder name to save the item in a new folder.
Folder names cannot contain 4-byte Unicode characters.
If your organization has set up content categories, click Assign categories and select up to 20 categories to help users find the item.
You can also start typing a category name to narrow the list of categories.
Optionally, provide tag terms separated by commas.
Tags are words or short phrases that describe the item and help users find the item when searching. Federal land is considered one tag, while Federal,land is considered two tags.
Optionally, provide a summary that describes the data.
Click Save.
The data file and the feature layer are separately added to My content.
If the file contained addresses or place-names, any that could not be geocoded to create features are shown in a separate review table. Open the hosted feature layer in Map Viewer, and click the Tables button. See Review locations in Map Viewer for instructions.
By default, only you and organization administrators can access the hosted feature layer. To allow others to access it, share the layer and file with everyone (the public), your organization, or members of specific groups. You can edit item details and change feature layer settings.
To share the hosted feature layer as a copy in a distributed collaboration, you must enable synchronization.
Publish an Excel file
You can upload an Excel file (.xlsx or .xls) to ArcGIS Online and publish a hosted feature layer from one of the worksheets. If the worksheet contains latitude and longitude information, coordinates, place-names, or addresses, you can publish a hosted feature layer from the worksheet. If no spatial information is present in the worksheet, you can publish a hosted table.
The following steps explain how to add an Excel file from your local drive and publish. For instructions to access and publish a file from a cloud drive, see Publish from files on a cloud drive.
If the file contains multiple worksheets, choose the one to publish from the Publish this sheet drop-down list.
By default, the first sheet in the spreadsheet is published.
Click Next.
Review the fields included and make changes as needed.
Choose a time zone from the Time Zone drop-down menu for the date fields in the file.
By default, date fields are assumed to be in the time zone of your browser. If the date fields in the file store values that use a different time zone, choose that time zone.
Tip:
Choose the information in the file that ArcGIS Online will use to locate features as follows:
If the file contains addresses from multiple countries or from a country not in the list, choose World.
Choose whether the locations are based on one or multiple fields.
Review the location fields if any exist.
If ArcGIS Online can identify which fields contain location information, it sets them automatically. However, you can change location fields if necessary by clicking inside the cell.
Click Next.
Provide a title.
Click Save.
Publish a shapefile
To web enable feature layers from shapefiles (packaged in a .zip file), upload the .zip file to your organization and publish. This creates an item for the shapefile and creates a hosted feature layer. This is a useful workflow if you do not have any ArcGIS products installed locally.
For information about using a shapefile to create a feature layer as part of a reproducible process, see the ArcGIS Data Pipelines help.
To publish a hosted feature layer from a .zip file containing a shapefile or shapefiles, complete the following steps:
Shapefiles must be compressed as a
.zipfile containing at least the.shp,.shx, and.dbffiles. If the shapefile does not include a.prjfile, the x,y domain extent must be between -180 and 180 degrees. If the data is not within this extent, an error occurs, and you must delete the feature layer.If there are multiple shapefiles in the
.zipfile, they are all included in the hosted feature layer.When you add a
.zipfile, specify the type of content in the file. Choose the data format from the Item type drop-down menu.You cannot upload the file if the wrong content type is specified.
Choose Add <file name> and create a hosted layer.
Click Next.
Provide a title.
Click Save.
The data file and the feature layer are separately added to My content. One way to test the new hosted feature layer once publishing completes is to view it in a map viewer.
If you publish a shapefile or shapefiles that contain metadata, that metadata is included in the layers in the hosted feature layer. When viewed from the hosted feature layer's item page, the metadata is displayed in the metadata style configured for the organization.
Tip:
If you edit features in the shapefile from a desktop application, you can upload the edited shapefile and overwrite the data in the hosted feature layer.
Publish a GeoJSON file
You can publish from a GeoJSON file on a local drive or access a GeoJSON file on the web to publish a hosted feature layer from the file.
For information about using a GeoJSON file to create a feature layer as part of a reproducible process, see the ArcGIS Data Pipelines help.
Publish from a local file
To web enable feature layers from a GeoJSON file (.geojson or .json), upload the file to ArcGIS Online and have them hosted as services. These services are referred to as hosted feature layers. This is a useful workflow if you do not have any ArcGIS products installed locally.
To publish, the GeoJSON file must be smaller than 100 MB.
The steps below outline how to publish features from ArcGIS Online using a GeoJSON file.
Click Next.
Provide a title.
Click Save.
Publish from a file on the web
If you have access to a GeoJSON file on the web, you can use the URL to the GeoJSON file to publish a hosted feature layer from it.
If the file is larger than 50 MB, creating a hosted feature layer from the file URL may not be supported.
To create a hosted feature layer from a larger file, download the file and publish from the file instead of from the URL.
Verify that you are signed in and have the privilege to create, update, and delete content.
From the My content tab of the Content page, click New item, and click URL.
Provide the REST URL of the GeoJSON file on the web.
The following is an example GeoJSON file on the web that is available to the public:
https://earthquake.usgs.gov/earthquakes/feed/v1.0/summary/4.5_week.geojsonChoose GeoJSON for the item type.
Click Next.
Choose the Add data and create a hosted feature layer option.
Click Next.
Provide a title.
Alternatively, choose Create new folder from the menu and provide a folder name to save the item in a new folder.
Optionally, provide tags that describe the item.
Separate the terms with commas (for example, Federal land is considered one tag, and Federal, land is considered two tags).
As you type, you can choose any of the suggested tags that appear; suggestions are generated from tags you previously added.
Optionally, provide a summary that describes the item.
Click Save.
After you add the GeoJSON file from the web using its URL and publish, the hosted feature layer item appears in your content, and you can edit the item details and share it if you have sharing privileges.
Publish the contents of a file geodatabase
To web enable a feature layer from a file geodatabase (packaged in a .zip file), you can upload the zipped file geodatabase to ArcGIS Online and have its contents hosted as a service. This service is referred to as a hosted feature layer.
Publishing file geodatabase contents is a useful workflow if the geodatabase contains only a few datasets. Each feature class in the file geodatabase will be a layer in the hosted feature layer.
You can publish the following data types from a file geodatabase to a hosted feature layer:
Feature classes (x- and y-coordinates; m- and z-coordinates are dropped)
Tables
Relationship classes
Parcel fabrics
Tip:
If the parcel fabric does not publish, your ArcGIS Online organization or your member account might not meet the requirements to publish parcel fabrics. Contact your organization administrator to confirm requirements are met.
Other data types—such as rasters and networks—remain in the geodatabase but are not included in the published hosted feature layer.
To add a file geodatabase to the website and publish its contents as a hosted feature layer, complete the following steps:
Find the file on your device or network.
The file geodatabase must be in a
.zipfile.Select the file and click Open.
When you add a
Click Next.
Provide a title.
Click Save.
The supported data in the file geodatabase is published as a hosted feature layer. It may take some time to upload the file and publish. When publishing completes, you can test the new feature layer by viewing it in Map Viewer. Views in the file geodatabase are not published but remain in the file geodatabase.
If the feature classes in the file geodatabase contain metadata, that metadata is included in the layers in the hosted feature layer. For each layer that has metadata, you can view the metadata from the hosted feature layer's item page, and the metadata is displayed in the metadata style configured for the organization.
Tip:
If you edit features in the feature classes in the file geodatabase from a desktop application, you can upload the edited file geodatabase and overwrite the data in the hosted feature layer.
Publish photos with locations
You can upload a compressed file (.zip file) containing photos that have geotags, and publish a hosted feature layer. ArcGIS Online creates points in the hosted feature layer based on the GPS information in each photo's geotag. The photos are stored as attachments to these points. No point is created for any photo in the file that does not include GPS information.
You can upload a .zip file that contains JPEG image files that are tagged using standard Exchangeable Image File Format (EXIF) GPS information only.
To add a collection of images and publish a point hosted feature layer with the images stored as attachments, complete the following steps:
The images must be in a
.zipfile.When you add a
Click Next.
Provide a title.
Click Save.
A point for each geotagged photo is created in the hosted feature layer. When publishing completes, you can test the new feature layer by viewing it in Map Viewer.
Publish the contents of an OGC GeoPackage
You can upload an OGC GeoPackage file and publish its contents as a hosted feature layer. One layer will be created in the hosted feature layer for each spatial table in the GeoPackage.
Publishing the contents of a GeoPackage is a useful workflow if the GeoPackage contains only a few tables.
You can publish the following data types:
Spatial tables that store point, multipoint, line, multiline, polygon, or multipolygon features
Nonspatial tables
Other data types in the GeoPackage file, such as tile pyramids and views, will not be included in the hosted feature layer.
To add a GeoPackage file to the portal and publish its contents as a hosted feature layer, complete the following steps:
Find the GeoPackage file on your device or network.
Choose Add <file name> and create a hosted feature layer.
If, instead, you add the file but don't publish a hosted feature layer, you can publish later from the GeoPackage item's page.
Click Next.
Provide a title.
Click Save.
The supported data in the GeoPackage file is published as a hosted feature layer. It may take awhile to upload the file and publish. When publishing completes, you can test the new feature layer by viewing it in Map Viewer.
Publish a feature collection
If the data needs to be edited by multiple people, you can publish a feature collection as a hosted feature layer, share the layer, enable editing on it, and use the feature layer in a map.
If you alter symbology for individual points in the feature collection, that symbology change is not preserved when you publish the feature collection as a hosted feature layer.
Feature collections and, therefore, the hosted feature layers published from them, use the WGS84 Web Mercator (Auxiliary Sphere) coordinate system for XY data.
To publish a feature collection, complete the following steps:
Open the item page of the feature collection.
Click Publish.
Use the default title for the hosted feature layer or provide a new one.
Tags are words or short phrases that describe the item and help people find it when searching. public buildings is considered one tag, while public,buildings is considered two tags.
Click Publish to create the hosted feature layer.
A hosted feature layer is created and added to your content.
Now you can share the hosted layer, enable editing, and add the feature layer to a map.
Publish from ArcGIS Pro
You can publish a feature layer from ArcGIS Pro to be hosted on ArcGIS Online. When you publish a hosted feature layer, data is copied from the data source to ArcGIS Online. The published hosted feature layer references the data in ArcGIS Online, not the data source.
The hosted feature layer stores data in the coordinate system of the ArcGIS Pro map from which you publish it.
Instructions for publishing a hosted feature layer from ArcGIS Pro are available in the ArcGIS Pro help.
If the layers in the ArcGIS Pro map have definition queries applied to them, ArcGIS applies the definition queries to the published hosted feature layer. However, all data is uploaded to ArcGIS Online. If you want only a subset of the data to be published to and stored in ArcGIS Online, you must export the subset of the data to another feature class and publish that.
If you intend to overwrite the hosted feature layer to update it, choose the Preserve layer IDs option when you publish the feature layer from ArcGIS Pro.
Create a layer from ArcGIS Data Pipelines
ArcGIS Data Pipelines supports a number of input data sources, including data stores, files, and public URLs. You can process the data from one or more sources, and publish hosted feature layers from the processed data.
See the ArcGIS Data Pipelines help for more information about the app and its workflows.
Define your own layer
When you define your own layer, ArcGIS Online creates a blank hosted feature layer containing the layers and fields you define. The resultant hosted feature layer uses the WGS84 Web Mercator (Auxiliary Sphere) coordinate system for XY data.
Tip:
When you define an empty hosted feature layer, attachments are enabled automatically on all sublayers except tables.
To define a layer, complete the following steps:
Verify that you are signed in with an account that has privileges to create, update, and delete content and publish hosted feature layers, and click the My content tab of the Content page.
Click New item and choose Feature layer.
Choose Define your own layer, and click Next.
Provide a name for the first layer in the feature layer, and choose the type of layer to create: Point layer, Line layer, Polygon layer, Multipoint layer, or Table.
To add more layers to the feature layer, click Add, and repeat the previous step for each layer.
Clicking Add places a new layer at the top of the list of layers. The order of the layers as they appear in this window is how the layers will appear in the hosted feature layer. Therefore, add layers in reverse order to how you want them to appear in the hosted feature layer.
Optionally, turn on the Enable GPS metadata toggle button if the layers need to store GPS information such as receiver name, accuracy, and fix type.
You can additionally enable the layer to store information specific to Global Navigation Satellite System (GNSS) receivers or laser rangefinders. If you use these data collection devices, turn on either or both of the following toggle buttons to add fields to the layers to store data specific to those types of devices:
Enable GNSS receivers
Enable laser rangefinders
When you edit the layer in the ArcGIS Field Maps mobile app, GPS metadata is recorded automatically. For more information about GPS metadata and collection, see Prepare for high-accuracy data collection in the ArcGIS Field Maps help.
To store z-coordinates with the layers, turn on the Enable Z-values toggle button.
To store m-values (measures) with the layers, turn on the Enable M-values toggle button.
When you finish adding the layers and tables you want in the hosted feature layer, click Next.
Provide a title.
Choose a folder in My content in which to save the hosted feature layer.
Click Save to create the feature layer.
When the feature layer is created, its item page appears.
Next, add fields to each layer and table, define attribute lists and ranges, define feature templates, and configure other settings that you require.
By default, editing is enabled on the new hosted feature layer, making it ready for data collection. If you don't want other people to edit it yet, disable editing by unchecking the Enable editing check box on the Settings tab of the hosted feature layer's item page.
Create from a template or existing feature layer
To duplicate layer properties while allowing members of your organization to populate the new layer with new features, create a hosted feature layer from an existing hosted feature layer, ArcGIS Server feature layer, or a template. When you do this, the fields from the existing layer or template are used in the new hosted feature layer, but the attributes (rows) are empty in the new layer.
For example, you may have a feature layer displaying the perimeter of an existing wildfire. When a new wildfire occurs, you can create an empty feature layer from the existing one. The new layer will have the same fields present, such as date_reported, percent_contained, and fire_crews_assigned, but the fields will not be populated. You can then populate the new layer with the boundary and attributes of the new wildfire.
The resultant hosted feature layer inherits the coordinate system of the template or existing feature layer you use to create it. The templates store XY data in the WGS84 Web Mercator (Auxiliary Sphere) coordinate system; therefore, a hosted feature layer you create from a template stores XY data in that coordinate system.
In addition to properties, the following layer configurations are copied from the existing hosted feature layer:
Aggregation
Blending
Charts
Custom parameters
Editing settings
Feature display order and transparency
Field formatting, visibility, and sorting
Filters (attribute and display)
Forms
Labels
Pop-ups
Refresh interval
Styles
Visible range
To create a hosted feature layer from a template or another feature layer, complete the following steps:
Choose an existing feature layer or template that contains the layers and schema to apply to the new feature layer.
This step doesn't add or copy any features to the new hosted feature layer; you're only defining the layers and schema of the new hosted feature layer.
If the existing feature layer or template includes m-values or z-values, the hosted feature layer you create will also have m- and z-values enabled. Similarly, if the existing feature layer or template has a default z-value, the hosted feature layer you create will use the same default z-value.
There are several approaches you can take, as described below:
Click Select an existing feature layer, click Next, choose the existing feature layer that you want to use as a template, and click Next.
Click Use a template, click Next, choose a template provided by Esri, and click Next.
Click Provide an ArcGIS Server layer URL, click Next, provide the URL of the existing ArcGIS Server feature layer to use as a template, and click Next.
No matter which approach you choose, check the check box next to each layer you want to include in the new feature layer.
You must include at least one layer.
When you finish choosing layers, click Next.
To add GPS metadata fields to layers and store GPS information such as receiver name, accuracy, and fix type to the feature layer, turn on the Enable GPS metadata toggle button.
Because GPS metadata fields require attachments, the layers you create will automatically have attachments enabled if you turn on the Enable GPS metadata option.
Click Next.
Provide a title for the new hosted feature layer.
Choose the folder in which to store the new hosted feature layer.
Optionally, provide tags and a summary for the new hosted feature layer.
Click Save to publish the new layer.
The item page of the new hosted feature layer appears.
If you used a template, editing and synchronization are enabled by default on the new hosted feature layer, making it ready for data collection. If you don't want other people to edit it immediately, disable editing on the Settings tab of the hosted feature layer's item page.
If you used an existing feature layer, the new hosted feature layer has the same editing settings as the source feature layer.
