Share a web feature layer
With ArcGIS Pro, you can share web feature layers to your ArcGIS Online or ArcGIS Enterprise portal. Web feature layers support vector querying, visualization, and editing. They are appropriate for visualizing data on top of a basemap and can be used as inputs for analysis and in sync-based workflows.
Web feature layers are shared in the following circumstances:
If you share a map image layer to ArcGIS Enterprise that references registered data, you can additionally choose to share a web feature layer. If you configure the Enable sync option for the web feature layer, see Prepare data for use in offline feature services.
To share a web feature layer, you must have the following:
  • An account that is part of an ArcGIS organization with the privilege to create content
  • An account with privileges to publish server-based layers (if you are sharing a web feature layer that references registered data to ArcGIS Enterprise)
  • An account with privileges to publish hosted feature layers (if you are sharing a web feature layer that copies all data to ArcGIS Enterprise or sharing to ArcGIS Online)
While in the process of sharing a web feature layer, you may decide to save a service definition instead. A service definition compiles information into a single file, allowing you to share the web feature layer at a later time. Information about saving a service definition is included in the workflow below. To learn more, see Introduction to saving service definitions.
You can also use ArcPy to share a web feature layer to a portal. To learn more, see Automate sharing web layers.
Share a web feature layer using the default configuration
This workflow explains how to share a web feature layer with default settings. To change the default configuration, see Configure a web feature layer.
  1. To share a web feature layer, do one of the following:
    • Share all usable layers in the map as a web layer. On the Share tab, in the Share As group, click the Web Layer drop-down arrow, and click Publish Web Layer .
    • Share selected layers in the map or scene as a web layer. Select the layers in the Contents pane, right-click any selected layer, point to Sharing, and click Share As Web Layer .
    The Share As Web Layer pane appears.
  2. Provide a name for the web layer.
  3. Optionally, complete the Summary and Tags fields.
    A summary and tags are required when sharing to an ArcGIS Enterprise 10.9 or earlier portal.
    You can use the Tags drop-down menu to select existing tags. You can enter a maximum of 128 tags.
  4. Optionally, use the Categories drop-down menu to assign content categories.
    You can assign a maximum of 20 categories.
  5. If your active portal is ArcGIS Online, for Layer Type, click Feature if necessary.
  6. If your active portal is an ArcGIS Enterprise portal, do one of the following:
    • Confirm that Map Image is selected under Reference registered data if you want to reference datasets in a registered enterprise database. Check the Feature check box to share the web feature layer as a dependent layer to the map image layer.
      If you are sharing a catalog, line, polygon, or oriented imagery layer in the 3D Layers category of a scene, a web feature layer is automatically included.
    • If you are publishing data from a cloud data warehouse, Elasticsearch, or OpenSearch, an additional Feature option may be available under Reference registered data. Select this option to publish a web feature layer that references registered data. Publishing data from the following cloud data warehouses and databases is supported to the corresponding portal versions:
      • Google BigQuery—ArcGIS Enterprise 11.0 or later
      • Snowflake—ArcGIS Enterprise 11.1 or later
      • Amazon Redshift—ArcGIS Enterprise 11.2 or later
      • Elasticsearch and OpenSearch—ArcGIS Enterprise 12.0 or later
    • Click Feature under Copy all data if you want to copy all the layers to the hosting server's managed database.
    For more information, see Understanding reference registered data and copy all data.
  7. Under Location, use the Portal Folder menu to choose a folder in your portal content to store the web layer. Optionally, create a folder.
    By default, the web layer is stored at the root level of your portal content.
    Tip:
    Click the Browse button to browse to a folder in your portal content. You can also type a folder name in the text box.
  8. Use the Server and Folder drop-down menus to specify the federated server where the service is published and the folder where it is stored. Optionally, create a folder.
    By default, the service is stored in the root folder of the server.
    The Server and Folder options appear only if you are sharing a web feature layer that references registered data to ArcGIS Enterprise. In this case, you can also click the Data Stores button to open the Manage Registered Data Stores pane. Use this pane to register geodatabases and folders with federated servers.
    If you are sharing a web feature layer that references registered data in a cloud data warehouse or Elasticsearch, only the Server drop-down menu is available. (The menu does not appear when sharing data in a cloud data warehouse to ArcGIS Enterprise 11.4 or earlier.) By default, the service is stored in a server folder named CDWFeatureLayers or DocDbFeatureLayers.
  9. Under Sharing Level, specify how the web layer will be shared:
    • Owner—Only the owner (and organization members with privileges to view content owned by other members) can access the item. This is the default option.
    • Organization—Share your content with all authenticated users in your organization. This option is available when you are signed in with an organizational account.
    • Everyone (public)—Share your content with the public. Anyone can access and see it.
    1. Optionally, under Groups, select groups to which you belong to share your content with their members.
  10. Optionally, click the Content tab to view the folder, new web layers, and sublayers with assigned IDs if available.
    If you enabled the Allow assignment of unique numeric IDs for sharing web layers option on the Map Properties dialog box, assigned IDs appear for each sublayer. To change an ID, click the number next to the layer or table. On the Layer Properties or Standalone Table Properties dialog box, on the General tab, type a custom integer ID in the Layer ID or Table ID text box. For more information, see Assign layer IDs.
  11. Under Finish Sharing, click Analyze to review for potential problems.
    Errors and warnings are listed on the Messages tab. Right-click a message to open its help topic or take corrective action in the software. Errors must be resolved before you can share your GIS resource. Resolving warnings is recommended but not required.
    Learn more about analyzing GIS resources
  12. After you have resolved errors, and optionally, resolved warnings, click Publish to share the web layer.
    To save a service definition for the web layer instead, click the Publish drop-down arrow and click Save As SD. To learn more, see Save a service definition for a web layer.
    The Save As SD option is not supported when sharing a web feature layer published from data in a cloud data warehouse, Elasticsearch, or OpenSearch.
  13. Optionally, click Jobs to monitor the job status.
  14. Once the web layer has been successfully published, click the Manage the web layer link to manage the web feature layer through your portal.
If you shared a web feature layer that references registered data, click the Manage the web layer link to go to the map image layer.
Considerations when sharing to portals
Although web feature layers can be shared to any portal, not all functionality is supported when sharing to ArcGIS Online or each version of ArcGIS Enterprise and Portal for ArcGIS. Limitations are listed below.
ArcGIS Enterprise 11.5 and earlier
  • Sharing data from Apache Parquet files as web feature layers that copy all data is not supported.
  • Sharing query layers from Elasticsearch or OpenSearch is not supported.
ArcGIS Enterprise 11.2 and earlier
  • Sharing subtype group tables is not supported.
ArcGIS Enterprise 11.1 and earlier
  • Sharing query layers from Amazon Redshift is not supported.
  • Sharing oriented imagery layers is not supported.
  • Sharing subtype group layers as web feature layers that copy all data is not supported.
  • Sharing catalog layers as web feature layers that reference registered data is not supported.
ArcGIS Enterprise 11.0 and earlier
  • Sharing query layers from Snowflake is not supported.
  • Sharing catalog layers is not supported.
ArcGIS Enterprise 10.9.1 and earlier
  • Sharing query layers from Google BigQuery is not supported.
ArcGIS Enterprise 10.8.1 and earlier
  • The Approve for public data collection option is not available.
ArcGIS Enterprise 10.8 and earlier
  • The Use symbol types compatible with all clients option is not available.
  • The Include topology layer option is not available.
  • Sync options are not available.
ArcGIS Enterprise 10.7.1 and earlier
  • Preserve editor tracking information is not available.
ArcGIS Enterprise 10.6.1 and earlier
  • Sharing data from a GeoPackage is not supported.
  • Sharing dimension layers as web feature layers is not supported.
ArcGIS Enterprise 10.6 and earlier
  • Assigning categories is not supported.
ArcGIS Enterprise 10.5.1 and earlier
  • Sharing annotation layers as web feature layers is not supported.
ArcGIS Enterprise 10.5 and earlier
  • The Time zone of the data option is not available when sharing web feature layers that copy all data.
Portal for ArcGIS 10.4.1 and earlier
  • The WFS layer is not available.
Portal for ArcGIS 10.3.1 and earlier
  • The data options are not available. Data is always copied to the server.
  • The Update feature attributes only editing option is not available.
