Overwrite a web feature layer
In addition to publishing new web feature layers, you can use ArcGIS Pro to overwrite existing web feature layers to reflect changes to a GIS resource or its source data. You can also modify the item description and configuration settings.
The following are requirements for overwriting an existing web feature layer:
You must be signed in as the owner of the web feature layer being overwritten or as a member of the default administrator role.
The location of the existing web feature layer in your portal must remain unchanged while the Overwrite Web Layer pane is open.
Change tracking must be disabled on the web feature layer.
If the existing web feature layer copies all data, either disable sync on the web layer or unregister any replicas.
While in the process of overwriting a web feature layer, you may decide to save a service definition instead. A service definition compiles information into a single file, allowing you to overwrite the web feature layer at a later time. Information about saving a service definition is included in the workflow below. To learn more, see Introduction to saving service definitions.
You can also use ArcPy to overwrite a web feature layer to a portal. To learn more, see Automate sharing web layers.
If you want to update the appearance of an existing web feature layer such as its symbology, pop-ups, or labels, but don’t need to change its source data or configuration, you can save the web layer instead. For more information, see Save a web feature layer.
Considerations when overwriting web layers
The existing web layer, including pop-ups and symbology, is always overwritten with what is authored in ArcGIS Pro. If you overwrite a web layer, its associated data is replaced. Changes to the pop-ups or symbology, or any other updates to the web layer after it was initially published, are lost. When overwriting a web layer, the schema of the new layer you are publishing can differ from the schema of the existing web layer if the new layer has different field names, deleted fields, or new fields.
Web maps store pop-ups and symbology separately from web layers. Pop-ups stored in the web map will not be updated if the web layer is overwritten with a newly configured pop-up. If the schema of a web layer changes, you may need to reconfigure the web map's pop-ups and symbology.
For example, you shared a web layer of United States cities and authored a web map that symbolizes the layer using the name field. When you overwrite the existing web layer with a new web layer with the name field renamed to city, the web map still tries to symbolize the layer using the old name field, even though it no longer exists. You must reconfigure the symbology using city as the new field.
Caution:
Before overwriting a web layer, it’s recommended that you click Compare
in the Overwrite Web Layer pane and verify that the IDs assigned to layers and tables in the map match existing service sublayer IDs. Otherwise, overwriting may break web maps consuming the service. For more information, see Assign layer IDs.
To overwrite a web feature layer that references registered data, overwrite its associated map image layer.
To overwrite a web layer, do one of the following:
Overwrite an existing web layer with all usable layers in the map. On the Share tab, in the Share As group, click the Web Layer drop-down arrow and click Overwrite Web Layer
.Overwrite an existing web layer with selected layers in the map or scene. Select the layers in the Contents pane. Right-click the selected layers, point to Sharing, and click Overwrite Web Layer
To overwrite a web feature layer published from data in a cloud data warehouse, Elasticsearch, or OpenSearch, the map or selected layers must contain query layers from a data warehouse, Elasticsearch, or OpenSearch. If your data is from a cloud data warehouse, your ArcGIS Enterprise portal version must be 11.5 or later. If your data is from Elasticsearch, your ArcGIS Enterprise portal version must be 12.0 or later. You cannot overwrite other existing web feature layers using these query layers.
The Overwrite Web Layer dialog box appears.
On the Overwrite Web Layer dialog box, browse to the location of the web layer in your portal, select it, and click OK.
Read the Overwrite Web Layer message and click OK to continue.
Caution:
If online edits were made to the web layer, or if features were appended to it, these changes will be overwritten.
The Overwrite Web Layer pane appears. On the General tab, under Item Details, the name of the web layer is displayed. The name can't be changed.
Under the layer name, choose one of the following options:
Use the item description from the web layer
The item description of the existing web layer is preserved. This is the default option.
Use the item description from the map or layer
The item description of the existing web layer is overwritten with the metadata of the map or layer.
Optionally, modify the information in the Summary and Tags fields.
The fields may be empty if you used the item description from the map or layer in the previous step. A summary and tags are required when sharing to an ArcGIS Enterprise 10.9 or earlier portal.
You can use the Tags drop-down menu to select existing tags. You can enter a maximum of 128 tags.
Optionally, modify the information in the Categories field.
You can assign a maximum of 20 categories.
Optionally, under Sharing Level, change the settings:
Owner—Only the owner (and organization members with privileges to view content owned by other members) can access the item. This is the default option.
Organization—Share your content with all authenticated users in your organization. This option is available when you are signed in with an organizational account.
Everyone (public)—Share your content with the public. Anyone can access and see it.
- Optionally, under Groups, select groups to which you belong to share your content with their members.
If you are the owner of the existing web feature layer, you can modify the group sharing settings.
Optionally, click the Configuration tab and change settings.
For more information about configuring the web layer, see Configure a web feature layer.
WFS layers are not supported when overwriting web feature layers. Overwriting a web feature layer that has an associated WFS layer breaks the WFS layer. In this case, delete and re-create the WFS layer from the item details page of the web feature layer.
Optionally, click the Content tab, and under Current map, view the folder, new web layers, and sublayers with assigned IDs if available.
If you enabled the Allow assignment of unique numeric IDs for sharing web layers option on the Map Properties dialog box, assigned IDs appear for each sublayer. To change an ID, click the number next to the layer or table. On the Layer Properties or Standalone Table Properties dialog box, on the General tab, type a custom integer ID in the Layer ID or Table ID text box. For more information, see Assign layer IDs.
Optionally, under Finish Sharing, click Compare
to review any discrepancies between the IDs in the current map and the existing web layer you are overwriting.Note:
If the Compare button
is disabled, ensure that the Allow assignment of unique numeric IDs for sharing web layers option is enabled on the Map Properties dialog box.A warning appears if discrepancies are found, such as mismatched pairs of IDs and layer names between the map and the existing web layer. You can hover over the warning symbol
next to an ID to view information about the warning. If desired, you can resolve discrepancies by changing assigned IDs or layer names in the current map. For more information, see Compare IDs when overwriting web layers.Click Analyze
to review potential problems.Errors and warnings are listed on the Messages tab. Right-click a message to open its help topic or take corrective action in the software. Errors
must be resolved before you can share your GIS resource. Resolving warnings
is recommended but not required.After you have resolved errors, and optionally, resolved warnings, click Publish
to share the web layer.To save a service definition for the web layer instead, click the Publish drop-down arrow and click Save As SD.
The Save As SD option is not supported when overwriting a web feature layer published from data in a cloud data warehouse, Elasticsearch, or OpenSearch.
Caution:
Publishing a service definition staged to overwrite will automatically replace the existing web layer if found on the server. To avoid unintentionally overwriting existing web layers and their associated data, store these service definitions in a way that makes them distinguishable from other service definitions.
Optionally, click Jobs
to monitor the job status.When the layer is successfully published, click the Manage the web layer link at the bottom of the pane to access the web layer in your portal.
Sign in to your portal, if necessary, to open the item page for the web layer, and open the layer in Map Viewer or use the Data and Visualization tabs on the item page to confirm that the web layer has been overwritten.
