Get started performing analysis
1. Ask and explore
Solving a spatial problem begins with a well-framed question based on your understanding of the problem. Getting the question right is key to deriving meaningful results. Questions that can be answered using spatial analysis include the following:
How many are in an area?
Which sites meet my criteria?
What are the characteristics of an area?
How is it distributed?
What is near what?
What is on top of what?
How is it related?
What is in the image?
Once you frame your question, explore and visualize data to refine and scope the question. There is an abundance of spatial data available to the public. Use web-based GIS to find the data you need, from ArcGIS Living Atlas layers, to data made public by users, to your own files and web layers. Exploring various data will help you understand aspects of the question you may not have considered, prompting you to further refine your question.
When you are satisfied with your question and have gathered the geographic data you want to use, add the data to a map and make any changes needed to better visualize it and prepare it for analysis.
2. Model and compute
Computers don't perform analysis; people do. ArcGIS includes a suite of analysis tools that can be used to manipulate, quantify, and manage your feature data to help you answer your spatial question. Raster analysis tools can be used to answer spatial questions with raster and imagery data. The Analysis pane includes pop-ups that help you plan and choose the right tools for your analysis.
Learn more about performing analysis
3. Examine and interpret
Once you process the data using the analysis tools, visualize the analysis results by examining the map. You can change the map's defaults to better visualize the data, including changing the style and transparency of the data, filtering out unnecessary data, and changing the basemap. Look for patterns in the map and speculate about what they might mean from a spatial or temporal perspective. Ask yourself whether the results provide an adequate answer to the question you asked. If not, you may need to adjust your approach. Is your question too broad or too narrow? Do you require more or different data? Should you use more or different analysis tools? Should you use different parameters?
Determine whether assumptions about the data, analysis methods, and mapping methods would alter the results. Also consider what artifacts of the data, analysis, and mapping processes deserve special attention.
4. Make decisions
After interpreting the results of the analysis, document your interpretation and decide how to respond. In some cases, you can take action based on your interpretation of the analysis results. You might implement a solution, correct a situation, create an opportunity, or mitigate circumstances. In other cases, no action may be required because your goal was to build knowledge and gain a deeper understanding. Often, new questions arise that need to be addressed, which can lead to further analysis.
5. Share results
Once you answer your question and are satisfied with the analysis, identify the audience that will benefit from your findings and determine who you want to influence. You may want to share the results with other members of your organization or the public. You can communicate the results using maps or apps. Creating an app, such as an ArcGIS StoryMaps story, is an effective way to share your findings.
Next steps
Try the following scenario-based tutorials to learn more about performing analysis:
