Calculate field values
Field calculations allow the hosted feature layer owner or organization administrator to alter the values of every row for a single field in the attribute table of a layer.
For example, if you have a hosted feature layer that stores information about property sales—including the sale price and tax rate for the property location—you could add a field to the layer to store estimated property taxes. To populate the estimated_property_taxes field, define a calculation expression for the field that multiplies the sale_price field values by the tax_rate values.
You can use ArcGIS Arcade or SQL to write calculation expressions on fields in layers in a hosted feature layer or hosted table, as described below:
ArcGIS Arcade—Arcade is recommended for calculations that require more functionality than SQL, as Arcade provides access to attribute values and feature geometry, allowing you to create expressions that include spatial operations. Additionally, if an error occurs while calculating a particular row, you can stop and troubleshoot the problem, and start the calculation again after you correct the problem.
ArcGIS API for JavaScript 3.44 and later will not be updated with the latest ArcGIS Arcade language features. Arcade expressions authored in JavaScript API apps at version 3.44 or later will only support Arcade language features introduced in Arcade version 1.21 or earlier. To learn more about Arcade language support across ArcGIS products, see the Arcade version matrix.
SQL—Use SQL for the fastest performance with calculations that can be performed with standardized SQL (SQL-92) expressions on nonspatial attributes. You can run SQL on sync-enabled hosted feature layers and tables and layers configured to track feature creators and editors, whereas you cannot run Arcade expressions on such layers.
There are many entry points to the field value calculation workflow. The next section explains one way to calculate values for a field and subsequent sections provide examples for common calculations.
Calculate values for a field from the item page
Complete the following steps to calculate string, numeric, or date field values in a field from the Table view on the Data tab of a feature layer or table's item page.
Caution:
Field calculations cannot be undone. For this reason, it is recommended that you add a field, calculate values into it, and confirm the calculation is what you wanted. If it is, you can then calculate the original field to equal the added field. Once you confirm the values are updated in the original field, you can delete the field you added.
Sign in to your organization.
You must be the owner of the hosted feature layer, hosted feature layer view, or hosted table or be an organization administrator.
Open the item page of the hosted feature layer, hosted view, or hosted table.
Click the Data tab to show the table.
Click the Options button
in the header of the column for which you want to calculate values and click Calculate.Calculated values will be written to the rows in this field.
Choose the language to use for the calculation, either Arcade or SQL.
If the item has sync enabled or is configured to keep track of who creates and updates features, only SQL is supported.
Optionally, click Add new in the Define filter panel to filter which values will be updated in the field when you run the calculation.
Filters allow you to restrict which rows are updated when you calculate. The filter can be based on values in another field or values in the field to update. You can apply more than one filter.
For example, to update a sales tax rate for all stores in a specific region in a table that stores information about fees, you can filter the region field for the value that represents the region to which the increase applies and calculate a new value for the
current_ratefield. Only rates associated with that region will be updated.Click Next to proceed with defining an expression.
Compose the calculation expression.
Tip:
Confirm that you are calculating values for the correct field. If the field name is incorrect, choose the correct one from the Field drop-down menu.
For SQL, type basic operators and functions.
For Arcade, use global variables, functions, and constants.
Tip:
You can use the ArcGIS Arcade assistant (beta) to generate ArcGIS Arcade expressions from instructions typed in natural language.
If you do not want the values for the test features to update as you compose the expression, turn off the Auto preview toggle button.
As you compose the expression, the original values and calculated values for the test features are displayed. This side-by-side comparison helps you determine if the calculation will result in the values you expect.
By default, the first 40 features in the layer are displayed as a test of the expression.
Only the comparison values for the test features are displayed. If there is an error for any feature in the test features, it appears at the end of the test feature table. Scroll over to view errors.
Optionally, define a filter or filters to alter which features are used for the test. To do this, complete the following steps:
Click Test features filter.
Click Add new and define a filter that returns the features to test.
To add another filter to limit which features are used for the test, click Add new, and define another filter.
Click Save when you finish defining the test feature filter or filters.
This filter does not affect which features are updated; it only changes which features appear in the preview pane. The preview is limited to 40 features, so only the first 40 features that meet the filter requirements will appear in the preview pane.
When you are finished composing the calculation expression, click Run calculation.
The time it takes for the calculation to complete depends on the expression's complexity and the number of features in the layer.
Example calculations
The following sections provide example syntax for performing common calculations in ArcGIS Online.
Perform a mathematical operation on numeric values in two existing fields to populate a third field
One of the most common calculations you perform is to derive a new numeric value based on existing values in your feature layer. For example, you might subtract one year's sales totals for all your stores from sales totals from another year to find the change in profit from one year to the next, or you might divide the total number of residents under 18 years of age by the total population to determine the fraction of the population that is under 18.
Arcade examples
Calculate the difference between the values of two numeric fields, Sales2016 and Sales2017, to populate a numeric field.
$feature.Sales2016 - $feature.Sales2017
SQL examples
Populate a numeric field with a decimal number that is the result of calculating what portion of the population is under 18 years of age.
PopUnder18/TotalPop
Concatenate string values from existing fields into a new string field
Another calculation that populates a new field involves combining values from existing string fields. For example, you might have two string fields for room locations in a hotel—Floor and Room—and you want to combine them into a string field that contains both.
In the following examples, values for the Floor and Room fields will be combined into a single field.
Arcade example
Concatenate($feature.room,$feature.floor)
SQL example
CONCAT(Floor,Room)
Remove trailing or leading spaces from string fields
When users type or paste values into a field when they're editing, they can make mistakes and leave a trailing or leading space on the text. You can clean up these mistakes by trimming the values.
In these examples, you know that the editor added a trailing space when pasting New Hampshire into the field that stores state names, so you will trim the space from the end of the string.
Arcade example
Trim('New Hampshire ')
SQL example
Trim(TRAILING ' ' FROM 'New Hampshire ')
Populate a field with different values depending on values in another field
Sometimes, the value you want added to a field varies by feature and depends on another value for the same feature. For example, you can add a string field to the feature layer to store text that describes a numeric or abbreviated string value in another field. As the SQL calculation interface does not support this, use Arcade for these types of calculations.
Arcade example
The following example conditionally writes different string values—None, Low, High, or Other—to a text field based on a number in another field in the layer (HowMany).
When(
$feature.HowMany == 0, "None",
$feature.HowMany == 1, "Low",
$feature.HowMany == 2, "High",
"Other")
Replace one value with another
If you need to replace an existing value with another—for example, if the way you represent a particular value has changed or you need to correct mistyped values—you can find all the existing values for a field and replace them with a new value. As the SQL calculation interface does not support this, use Arcade for these types of calculations.
Caution:
Calculations are immediately saved to the feature layer. If you overwrite an existing value in error, you'll need to calculate again to change the value back.
Arcade example
This example uses the Replace function to change the British spelling of colour to the American spelling of color.
Replace($feature.color, 'colour', 'color')
Determine the density of a numeric attribute per feature area
To calculate the density of one attribute in an area, use an Arcade expression, as you cannot perform SQL calculations on the spatial field from the calculation interface.
Arcade example
This example determines population density per feature by dividing the total population value (TotalPop) by the area in square miles of the polygon feature:
$feature.TotalPop / Area ($feature,
'square-miles')
Derive the coordinate for a point feature
You can use an Arcade expression to return the longitude or latitude coordinate for the spatial fields in a hosted feature layer that contains only points.
This type of calculation is not supported on the spatial field from the calculation interface.
Arcade example
This example calculates a field to the x-coordinate for each point in a point layer using the Geometry function.
Geometry($feature).x
Add time to or subtract time from a date
You may want to add time to or subtract time from a date field or date literal value to produce an updated date field. For example, you can calculate a future inspection or review date by adding time to a date.
Arcade example
This example uses the DateAdd function to add seven days to a date to obtain the following week's date.
var startDate = Date($feature.dateField);
var oneWeekLater = DateAdd(startDate, 7, 'days');
return oneWeekLater;
SQL examples
The following calculations can be used to add time to or subtract time from a date field or using an SQL-supported date literal value. The first one uses date fields and the second uses date literal values. Number fields and number literals can also be used. Any combination of fields and literals is supported, as shown in the third and fourth calculations.
<DateField> +/- <NumberField> = updated date
DATE'<SQL-supported Date Literal>' +/- <Number of Days> = updated date
<DateField> +/- <Number of Days> = updated date
DATE'<SQL-supported Date Literal >' +/- <NumberField> = updated date
The calculated date field is the original date plus or minus the number of days you want to add or subtract. The number of days can be a whole number and can also include a fraction—for example, 1.5 would represent one and a half days, or 36 hours.
In the following example, a piece of machinery is installed on 6/14/2016 at 10:00 a.m. You could use either of the following calculations to produce an inspection date one month (30 days) after this installation date. The first calculation uses a date field with a value of 6/14/2016 and a number field with a value of 30, while the second one uses a date literal and a number literal.
<MyDateField> + <MyNumberField> = 7/14/2016 10:00 AM
DATE'6/14/2016' + 30 = 7/14/2016 10:00 AM
Calculate the difference between two dates
You can calculate the length of time between two dates. For example, if you have the installation dates for electric meters and you also have inspection dates, you can calculate the difference between the two dates to verify that the length of time between installation and inspection falls within allowable guidelines. The result of the calculation is a number field rather than a date field.
Arcade example
The following example uses the DateDiff function to calculate a person's age by finding the difference between a current date (endDate) and the person's birth date (startDate):
var startDate = Date($feature.startDateField);
var endDate = Date($feature.endDateField);
var age = DateDiff(endDate, startDate, 'years');
return age;
SQL examples
Any combination of date fields and date literals can be used to calculate the length of time between two dates. The first calculation below uses a date field, while the second uses a date literal. The third and fourth calculations use both a date field and a date literal.
<DateField1> - <DateField2> = number of days in between
DATE'<SQL-supported Date Literal>' - DATE'< SQL-supported Date Literal>' = number of days in between
<DateField1> - DATE'<SQL-supported Date Literal>' = number of days in between
DATE'<SQL-supported Date Literal>' - <DateField2> = number of days in between
The result is a number field that is calculated by subtracting one date field or literal from another date field or literal. The number result (in days) can be a whole number and can also include a fraction—for example, 1.5 would represent one and a half days, or 36 hours.
In the electric meter inspection example mentioned above, any of the following calculations can be used to calculate the length of time between an installation date of 6/1/2015 and an inspection date of 10/1/2015. The first calculation uses date fields, the second uses date literals, and the third and fourth use both a date field and a date literal.
<InspectionDateField> - <InstallationDateField> = 122 (days)
DATE'10/1/2015' - DATE'6/1/2015' = 122 (days)
<InspectionDateField> - DATE'6/1/2015' = 122 (days)
DATE'10/1/2015' - <InstallationDateField> = 122 (days)
Considerations when calculating field values
Keep the following in mind:
When writing SQL expressions in the Calculate field interface, use field names, not field aliases. The Fields list shows you all the field names available for calculations. The list is organized by the field types String, Numeric, and Date.
If you click a field name in the Fields list, the field is added to the expression.
You cannot calculate field values in copies of hosted feature layers or for hosted feature layers that have related tile layers.
Calculated values are not propagated from the hosted feature layer or view to the dependent hosted 3D object or 3D point layer.
Locale-specific formatting is not supported for numbers in SQL expressions. For example, you must use a decimal point separator for attribute table values rather than a comma separator when the locale is set to Spain.
You cannot use the numeric
MODfunction on double fields. Cast the field to an integer as shown in the example.You cannot write Arcade expressions for hosted feature layers that have sync enabled or are configured to track who created and last updated features.
Standardized SQL (SQL-92) reference
When you write an SQL expression to calculate field values, use standardized SQL. This section provides a list of the operators and SQL functions you can use for SQL calculations in ArcGIS Online.
After you create an SQL expression, click the Run calculation button. If there are any errors, an error message appears. Correct the expression syntax and calculate again.
Operators
On the Calculate Field dialog box, you can build simple SQL expressions using operators such as plus, minus, multiply, and divide. Examples and tips for using these operators are as follows:
To multiply all values in a numeric field named
SAMPLEby 100.0, type SAMPLE * 100.0 for the expression.For more complex equations, you can use the parentheses to specify the order of calculations, for example, SAMPLE * (BASELINE - 40).
Math operators do not work with string fields. You'll need to use the string functions described in the String functions section.
If you are calculating a field of type double to a field of type integer, the
CASTfunction may be automatically added to your expression. For example, if you're calculating a double field namedPOPto an integer field namedSAMPLE, the expression will appear as CAST(SAMPLE AS FLOAT). Do not remove theCASTfunction. See Numeric functions below for information on theCASTfunction.To include an apostrophe in the string, use two single quotation marks for the apostrophe. For example, 'Nightingale''s'. Do not use a double quotation mark.
Functions
In addition to simple expressions using operators, you can also use functions to build SQL expressions. Functions work with field names, literals, and other functions. For example, suppose you need to calculate a double field to be TOTALPOP divided by POP18. If any feature has a POP18 equal to zero, the calculation will result in a divide-by-zero error. You can guard against this using the NULLIF function described below. The expression would be TOTALPOP / NULLIF(POP18, 0).
Functions take arguments. In the tables below, any argument can be as follows:
A field name, as long as the field type matches the argument type (string, number, or date).
A literal, such as 'Sailboat' (a string surrounded by single quotation marks), the number 5, a date in MM/DD/YYYY hh:mm:ss or YYYY-MM-DD format, or a time in HH:MM:SS format, surrounded by single quotation marks.
A function that returns a value of the proper type (string, number, or date). For example, FLOOR(POWER(SAMP_ERR, 0.5)) returns the largest integer that is less than or equal to the square root of
SAMP_ERR.
For illustrative purposes, the examples in the description column of the following tables mostly use literal arguments. You can substitute a field name or another function for these arguments.
Date functions
Several calculations can be performed on date fields. For example, you can add or subtract time from a date field or calculate the difference between two date fields.
Before working with date fields, read about date and time considerations.
You can use any combination of date and number fields and literals when calculating date fields. When using date literals, you must use SQL-supported date formats.
The following date functions are available:
Function |
Description |
Returns the current date in UTC time. What value is displayed depends on the client you're using. In ArcGIS Online, dates are shown in the time zone for your organization or profile. |
Returns the current UTC date and time (hours, minutes, seconds). What value is displayed depends on the client you're using. In ArcGIS Online, time is displayed in the local time of your organization or profile. |
Returns the current UTC date and time (hours, minutes, seconds, milliseconds). What value is displayed depends on the client you're using. In ArcGIS Online, time is displayed in the local time of your organization or profile. |
Returns a single part ( The following examples extract different units from the date-time value 2016-12-21 15:11:
Numeric functions
Function |
Description |
Returns the absolute (positive) value of the number you specify. |
Returns an angle that is the inverse cosine of the number you specify. Both the specified number and the inverse cosine are in radians. |
Returns an angle that is the inverse sine of the specified number. Both the specified number and the inverse sine are in radians. |
Returns an angle that is the inverse tangent of the specified number. Both the specified number and the inverse tangent are in radians. |
Converts a number to a different type. In the first example below, the number is cast to an integer. Because integers are whole numbers, the result is 1424. In the second example, an integer is cast to a float, which results in a number with decimal places, 1424.0
Returns the smallest integer greater than or equal to the specified number. The following example returns 13:
Returns the trigonometric cosine of the specified number, which is assumed to be an angle in radians. |
Returns the largest integer that is less than or equal to the specified number. The following example returns 12:
Returns the natural logarithm of the specified number. |
Returns the base-10 logarithm of the specified number. |
Returns the remainder after the dividend ( Examples include the following:
Returns Whenever a calculation encounters a For example, suppose you need to calculate a double field to be
Returns the value of the specified number raised to the specified power ( The following example returns 32768:
Rounds the number you specify to the specified length. If you use a positive number for the Examples are as follows:
Returns -1, 0, or 1 to indicate the sign of the result of the number. If the expression results in a number smaller than 0, If the expression result is 0, If the expression results in a number larger than 0, For example, if you add the values of two integer fields,
Returns the trigonometric sine of the specified number, which is assumed to be an angle in radians. |
Returns the tangent of the specified |
Truncates the A positive In the first example, the numbers to the right of the decimal place are truncated to include only two numbers, resulting in the value 111.99. In the second example, the numbers to the left of the decimal place are truncated, resulting in the value 100.00.
String functions
Function |
Description |
Converts the string to a date or time if the string value is in a supported format. If the string is in the format For example, the following string can be cast to a date:
Returns the number of characters in the specified string. The result is an integer. For example, the following statement returns 8:
Returns the first non-null value in the expression. For example, to ensure a value that you use in a subsequent calculation isn't a null value—such as when you are dividing one value by another—you can provide a list of fields and COALESCE will return a non-null value.
Another example is three mutually exclusive string fields in a survey for which responders will provide a value for only one field. You can use the
Concatenates two string values. Only two strings can be provided. To concatenate more than two strings, nest consecutive The first example below concatenates the letters A and B. The second example shows a nested
Null values are converted to an empty string. |
When the For example, if the user, planner3, is signed in to the organization to access a hosted feature layer view that contains the following query definition, only features in which the
In the next example, multiple values are stored in the
Returns the position of the first occurrence of the specified substring in the string you specify. If the specified substring is not found, the result is 0. In the first example below, the result is 5 because the first letter (
Returns a part of a string value. See the following examples:
Returns a string in which all leading or trailing spaces are removed from the string you specify. In the following example, a space exists before and after the string,
This returns the string |
Returns a string in which all characters are converted to uppercase. In the following example, all letters in the string
Returns a string in which all characters are converted to lowercase. In the following example, all letters in the string
