Data access and editing
As the owner of a hosted feature layer or an organization administrator, you need to decide who has access to your feature layer data. You can control that through a combination of hosted feature layer views, editing settings, and sharing properties.
To determine whether you need to create hosted feature layer views, with whom you should share your hosted feature layers and hosted feature layer views, and which editing properties to set, consider the questions below.
Who needs to edit?
The owner of the hosted feature layer and the organization administrator can always edit in Map Viewer even if editing isn't enabled on the layer. This is useful if the layer is intended for viewing purposes but requires occasional edits. It is also useful if you're part of a small organization in which the publisher and editor are the same person. Basically, if you don't need to make the layer available for editing by everyone, don't.
If you do need other members of your organization to edit the hosted feature layer, enable editing on the layer and share it with the appropriate set of people. Be aware that when you share the layer with a group or the organization, only those members who are assigned a role that includes editing privileges can edit the feature layer. When you share the feature layer with the public, anyone—even people not signed in to your organization—can edit the layer. To ensure you don't accidentally share an editable layer with the public, you must enable public data collection on the hosted feature layer or hosted feature layer view.
Does everyone need to make the same types of edits?
You decide what type of editing is allowed when you enable edits on your hosted feature layer. There are several combinations of editing options you can enable. For example, you can configure the layer so that editors can add, update, and delete features or restrict editing so that editors can only add features or only update attributes.
If everyone who will edit the layer will be doing the same types of edits, all you need is a single hosted feature layer with one setting. As mentioned in the previous section, you still have full editing control on the layer no matter what you enable for others.
If you want different people to perform different types of edit operations, a single hosted feature layer isn't enough. To meet this need, create a hosted feature layer view from the hosted feature layer, enable different editing options on the view, and share the view with the appropriate set of people. You can create multiple views if needed to meet different editing requirements.
Legacy:
If most of your editors will perform the same types of edits but you need several people to have full editing control (add, update, and delete), the organization administrator can create a shared update group whose members have full editing control of all hosted feature layers that are shared with the group. Although this group option still exists, it is part of a workflow that has effectively been replaced by creating a view. Use of a view is preferable, as it provides more control over who can edit a specific layer, whereas members of a shared update group have full editing privileges on all hosted feature layers that are shared with the group.
What if you want some people to edit but not others?
Similar to when different editors need different levels of editing access, you can create hosted feature layer views to meet this need. You can enable editing on the hosted feature layer and share it with only the group or groups whose members need to edit the layer. Next, create a hosted feature layer view from the editable hosted feature layer but disable editing for the view. Share the view with the sets of people who need read-only access to the data. This is useful if you want the public or your entire organization to view the features but only need a few organization members to edit it.
Can you keep track of who edits your data?
You can enable editor tracking on hosted feature layers. This adds fields to your layer to record the login credentials of the person who creates a feature and when he or she created it, as well as fields to record who last edited a feature or its attributes and when it was edited.
Enabling editor tracking allows you further control over the types of edits people can make to the layer. For example, you can restrict editors to only editing the features they add to the layer or only allow editors to see the features they add.
Do you need to restrict editing to a particular geographic area?
Create hosted feature layer views that provide access to specific geographic areas. This is useful, for example, if you have multiple editors who are responsible for different geographic regions. You can create a view, define an area of interest that corresponds to one region, and share it with a group whose members need to edit that region. Then create additional views for each additional region and share them with the appropriate groups.
Do you want to restrict editing to particular features or attributes?
Create hosted feature layer views and set view definitions that restrict the features or nonspatial attribute fields people can access through the view.
For example, if you have a single hosted feature layer that contains buildings in your city, you might need to create views with the following definitions:
  • Create one view for members of the public who want to look up information about a property. Configure the view so only those fields that store information that the public is allowed to see are available. Do not enable editing on this view and share the view with everyone (public).
  • Create another view to be used by city staff who inspect or issue permits for commercial properties. Set a definition on the view that exposes only those building features that are defined as commercial and share the view with a group composed of the appropriate city staff.
  • Create another view to be used by city staff who inspect or issue permits for residential properties. Set a definition on the view that exposes only those building features that are defined as residential and share the view with a group composed of the appropriate city staff.
Do you want to restrict access to certain layers in the hosted feature layer?
If your hosted feature layer contains multiple layers, create a hosted feature layer view from the details page of the individual layer or layers that you want to share. If you want editors to edit one or more of the sublayers, enable editing on the appropriate hosted feature layer views and share them with groups of editors. You can also set definitions on the views that restrict which fields are available.
For example, if you have a hosted feature layer that contains park areas, structures, trails, and sprinkler systems, you can create the following hosted feature layer views:
  • Create a view of the park structures. Define the view to expose a single field that allows the park patrons to report problems with the structures, such as clogged sinks, graffiti, or broken playground equipment. Enable editing on the view but only allow updates to attributes. Enable public data collection and share the view with the public.
  • Create a view of the trails. As with the structures, you can set a view definition that makes a single attribute field available that the public can use to report problems with the trail, such as overgrown vegetation or mountain lion sightings. Enable editing on the view but only allow updates to attributes. Enable public data collection and share the view with the public.
  • Create a view of the sprinkler systems. Enable editing on the view and share it with a group that contains the grounds keepers who install and maintain the sprinklers.
Will some editing take place when internet connectivity isn't available?
If you have mobile workers who need to edit data outside the office, where they likely cannot connect to your organization, you can enable your hosted feature layer for synchronization (offline editing).
Use your sync-enabled hosted feature layer in the surveys you create with ArcGIS Survey123 to allow you to collect information while offline.
To use your sync-enabled layer in ArcGIS Field Maps or custom apps built with ArcGIS Maps SDKs, create a map that is enabled for offline use, add your sync-enabled hosted feature layer to it, and add other layers your offline editors will need for reference.
