Manage hosted imagery layer settings
You can alter certain settings on a hosted imagery layer. The following sections describe how the layer owner, or an organization administrator, can manage the settings for a hosted imagery layer and the data it contains.
Manage the item page
As the owner of a hosted imagery layer, or an administrator, you can change the name, thumbnail, summary, description, terms of use, sharing settings, folder, tags, and acknowledgments of hosted imagery layer items. An administrator can change the owner of a hosted imagery layer.
On the tabs on the Content page, additional information about the imagery layers can be viewed with the type attributes. For imagery layers, you can see the following attributes within parentheses:
hosted—Indicates that the imagery layer is hosted in ArcGIS Online
collection—Indicates that it is a dynamic imagery layer with an image collection
multidimensional—Indicates that the imagery layer is multidimensional and can be configured with the multidimensional settings in Map Viewer
These imagery type attributes allow you to locate imagery layers within your organization quickly.
To change a hosted imagery layer property, complete the following steps:
Sign in to your organization, and open the item page for the hosted imagery layer.
On the Overview tab, click the Edit button next to the property you want to change.
Change the property, and click Save.
You cannot share dynamic imagery layer items with the public. Even if you have privileges to share data publicly, the option to share dynamic imagery layers using the Everyone (public) option is not available.
Manage general settings
As the owner of a hosted imagery layer, or an administrator, you can modify the content status, the deletion management setting, and the extent of the layer.
To change the general settings, complete the following steps:
On the Settings tab, turn on the Mark as Deprecated toggle button if necessary to discourage the use of this item.
Optionally, turn on the toggle button to prevent the item from being accidentally deleted.
To set an extent to make the layer searchable by location, click Edit extent.
When finished, click Save.
Manage dynamic imagery layer settings
Hosted dynamic imagery layers have additional settings such as default resampling, compression, mosaic methods, and mensuration that can be modified by an administrator or owner of the dynamic imagery layer.
Modify image request options
You can modify the limitations on the size of the imagery that is queried or displayed when rendering an imagery layer. For example, increase the size of the request to display a larger area of imagery.
To modify the portions of the imagery layer that can be queried and displayed in the map, complete the following steps:
Sign in to your organization, and open the item page for the hosted dynamic imagery layer.
Click the Settings tab.
Scroll to the Imagery layer (hosted) section.
Optionally, modify one of the following settings:
Tip:
These settings control the visualization and the ability to use the imagery layer in raster analysis. The settings here control how much can be processed in the raster analysis tool or function. For example, if the processing extent of the raster analysis tool exceeds the maximum rows and columns, the tool will fail. These settings can improve the performance of the imagery layer, so consider the performance when modifying.
Maximum columns per request—The maximum number of columns that the server allows in a client request. If the client’s request exceeds this value, none of the pixels will be returned.
The request size limit for the ArcGIS Online dynamic image service is set to 4,000 by 4,000 pixels or smaller. You can adjust the size of the Maximum columns per request value, but this parameter setting will revert to 4,000 pixels if you specified more than 4,000 columns.
Maximum rows per request—The maximum number of rows that the server allows in a client request. If the client’s request exceeds this value, none of the pixels will be returned.
The request size limit for the ArcGIS Online dynamic image service is set to 4,000 by 4,000 pixels or smaller. You can adjust the size of the Maximum rows per request value, but this parameter will revert to 4,000 pixels if you specified more than 4,000 rows.
Maximum samples count—This generates sample point locations, pixel values, and corresponding spatial resolutions of the source data for a specified geometry. By default, the maximum number of sample locations is 1,000.
Set the default resampling method
The default resampling method specifies how pixels are displayed when the imagery layer is added to a map. For example, you can change the resampling method from Bilinear Interpolation to Nearest Neighbor if most of the imagery in the collection is categorical.
To change the default resampling method for imagery display, complete the following steps:
Scroll to the Imagery layer (hosted) section, and select one of the following options for the Default resampling method setting:
Nearest Neighbor—Recommended for discrete data
Bilinear Interpolation—Recommended for continuous data
Cubic Convolution—Recommended for continuous data
Majority—Recommended for discrete data
Choose the compression options
Compressing raster data improves performance over a network.
To specify the allowed compression types, complete the following steps:
Scroll to the Imagery layer (hosted) section, and turn on the toggle buttons to allow one or more of the following options for the Allow compression setting:
None—No compression will occur.
JPEG—Lossy compression that uses the public JPEG compression algorithm. If you choose this setting, you can also specify the Default JPEG compression quality setting. The valid compression quality value range is from 0 to 100, with 75 being the default. This compression can be used for JPEG and TIFF formats and geodatabases.
LZ77—Lossless compression that preserves all raster cell values.
LERC—Lossless or lossy compression that divides the raster into a number of pixel blocks—in which each pixel can be quantized and bit stuffed—based on a number of block statistics, including the maximum error allowed.
Change the processing template
You can render dynamic imagery layers using processing templates, which process pixel values on the fly to generate a display showing the results.
Processing templates provide different preset visualization options for a user to choose when working with a dynamic imagery layer. For example, you can add a processing template to display the layer in a different band combination, such as a false color composite. Then, a user working with the layer can apply this processing template instead of changing the band combination manually.
To allow and specify the processing templates available to render a dynamic imagery layer, complete the following steps:
Scroll to the Imagery layer (hosted) section, and turn on the Allow processing templates on the layer toggle button to allow users to access the processing templates associated with the layer.
Click the Choose processing templates button.
In the Choose processing templates window, browse to the processing template you want to add to the dynamic imagery layer, and click the Select button.
The processing templates you add to the layer will be listed under Custom processing templates.
Optionally, if you add more than one processing template, under Default processing template, choose a template as the default renderer for the imagery layer.
Specify mosaic options
If the imagery layer was generated from a mosaic dataset or a collection of images, you can modify the mosaic or catalog properties of the imagery layer. These properties control or limit the access users have to metadata and the catalog fields, as well as limit the requests for records from the mosaic dataset tables. These properties can affect the load on the server. The more you allow a user to view and query, the greater the draw on the server.
Caution:
This setting is only available for dynamic imagery layers with the collection type attribute.
To modify the mosaic or catalog properties of the dynamic imagery layer, complete the following steps:
Scroll to the Imagery layer (hosted) section, and turn on the Catalog toggle button.
Optionally, modify one or more of the following settings:
Maximum number of rasters per mosaic
The maximum number of rasters that can be mosaicked per request. This prevents the server from opening and performing processing on large numbers of rasters for a single request.
If the client's request requires more than this number of rasters to be accessed, only this number of rasters are accessed. None of the pixels for the additional rasters are returned, potentially causing gaps in the resulting image. It is recommended that overviews be built so that the client does not end up with gaps in the display.
Maximum number of records returned per request
The maximum limit of the number of records transmitted per transaction. If a user’s request exceeds this value, the image returned uses the maximum allowed rasters.
Allowed fields
The fields in the attribute table that are transmitted to the client. Turn off the toggle button next to the fields that you don't want a client to view or use in a query.
Allowed mosaic methods
The allowable mosaic methods for the image service. The possible mosaic methods are as follows:
Closest to Center
North-West
Lock Raster
By Attribute
Closest to Nadir
Closest to Viewpoint
Seamline
None
If you choose By Attribute, you can specify the Mosaic method sort field setting and the base Sort value setting.
Allow mensuration types
To allow image mensuration on the imagery layer, including tools to measure point, distance, area, and feature height from an image, complete the following steps:
Scroll to the Imagery layer (hosted) section, and turn on the Mensuration toggle button to allow users to perform measurements in the imagery layer.
Turn on the toggle buttons to allow one or more of the following mensuration options:
None—No mensuration can be performed.
Basic—The basic mensuration operations can be performed: point, distance, area, and centroid.
Base-Top Height—Height measurement can be performed from the base of an object to the top of the object. Measurements are assumed to be perpendicular to the base; the line being measured along the building must have its endpoint directly above the start point. Measurements will not be as accurate for objects that taper or lean from the base.
Base-Top Shadow Height—Height measurement can be performed from the base of the object to the top of the object's shadow on the ground. The point in the shadow must represent a point on the visible object that is perpendicular to the base.
Top-Top Shadow Height—Height measurement can be performed from the top of the object to the top of the objects's shadow on the ground. The measurement points on the object and its shadow must represent the same point. This option is useful for obtaining the height of an object on the top of a structure, for example, if there is a smaller room than the dimensions of the building or a tower on the top. You can identify the top point of this feature in the image and identify the same point in the shadow.
3D—The 3D mensuration operations can be performed: 3D point, 3D distance, 3D area, 3D centroid, and volume.
