Ask the ArcGIS Pro assistant (beta) for help
You can ask the ArcGIS Pro assistant (beta) questions about the features and capabilities of ArcGIS Pro 3.8. The assistant can provide information about this software version only. It cannot provide information from other resources such as Esri Community posts or Esri Technical Support content.
You can ask for definitions of terms, explanations of concepts, and guidance on accomplishing workflows or resolving problems. Prompts do not always need to be formed as questions. For example, you can use questions, phrases, or statements such as the following:
  • What is a pour point?
  • Spatial interpolation.
  • How do I change the feature selection color?
  • How can I make ArcGIS Pro run faster?
  • I don't see a pop-up when I click a feature.
Questions should be phrased in natural, conversational language. Spelling and grammar do not need to be perfect.
The assistant can’t answer questions that are outside the scope of its knowledge, that it does not understand, or that cross its ethical guidelines. If the assistant replies that it cannot help you, you can try rephrasing the question. If that doesn't work, you can provide feedback.
Start a conversation
When the Assistant (Beta) pane is open in ArcGIS Pro, you can ask the assistant a question.
To start a conversation with the assistant, complete the following steps:
  1. In the Assistant (Beta) pane, click the menu button , and click ArcGIS Pro Help .
  2. In the box at the bottom of the pane, enter a natural-language question or prompt, and click Ask the question .
    The answer appears in the pane with one or more links to relevant documentation. In some cases, the assistant may ask you to clarify the question. If follow-up questions are returned, you can click any of them to ask them within the current conversation.
    Tip:
    To cancel a question, click Cancel in the window. The question and the cancellation message remain in the conversation history.
  3. Optionally, continue the conversation by asking another related question. Alternatively, click New conversation to change the subject.
Subsequent questions are part of the same conversation until you start a new conversation. During a conversation, the assistant uses the context from previous questions to influence its answers to later questions. Changing the subject within a conversation may lead to incorrect or confusing answers. It also makes it harder for you to keep track of your conversation history.
Ask follow-up questions
Follow-up questions are provided in a collapsible section at the end of each response. If one of these follow-up questions aligns with your intent, click it to automatically submit it as the next question to the assistant.
