Create a graph query with the ArcGIS Pro assistant (beta)
Use the ArcGIS Pro assistant (beta) to generate openCypher queries for a specified knowledge graph schema by asking questions in natural, conversational language. The resulting queries can be used in knowledge graph workflows.
To query a knowledge graph using the assistant, complete the following steps:
In the Assistant (Beta) pane, click the Graph Query card, or click the menu button
, and click Graph Query
.Click the Data Connection drop-down arrow and click the name of the knowledge graph to query.
In the prompt text box, enter a natural-language question about the knowledge graph.
Press Enter or click Ask the question
to submit the prompt.Once a query is generated, expand the Explanation heading to see the reasoning used to generate the graph query.
Optionally, click Add to current investigation to add the query to the currently active investigation, where you can also run the query.
Optionally, continue your conversation by submitting follow-up questions.
