Perform linear referencing system route editing with the ArcGIS Pro assistant (beta)
You can use the ArcGIS Pro assistant (beta) in ArcGIS Pro Actions mode to perform linear referencing system (LRS) route editing.
Learn more about ArcGIS Linear Referencing
The following requirements apply:
The Linear Referencing license must be authorized.
Learn more about authorizing and managing extension licenses in ArcGIS Pro
Only data from a feature service (published from branch versioned data) is supported.
The following table shows sample prompts and results for each LRS route editing type:
| LRS route editing option | Sample prompt | Result |
| Route creation | Create a route. | If only one LRS Network is found on the map, you are asked to provide a route ID or route name. If multiple LRS Networks are found on the map, you are asked to specify an LRS Network. If the LRS Network is configured with a multifield route ID, you are asked to provide a field name and the attributes for each field that is part of the multifield route ID. |
| Route creation | Create a route R1 in the all roads network using centerlines with object ID 102 and 103. The start measure is 0 and the end measure 0.8. The effective date is 1/1/2010. | The Create Route pane is populated. |
| Route reversal | Reverse a route. | You are asked to provide a route ID or route name. |
| Route reversal | Reverse route R1 from 1/1/2010 in the county log network. | The Reverse Route pane is populated. |
| Route realignment | Realign route R1 in the county log network. | If the centerlines are selected on the map and touch the route, the Realign Route pane is populated. |
| Route realignment | Realign route R1. The source from measure is 0 and the source to measure is 0.882. Use centerlines 102, 103, and 104. The network is LineNetwork, and the effective date is 01/10/2000 in LineA. Recalibrate downstream and reassign to abandoned routes. | The Realign Route pane is populated. |
| Route realignment | Realign a route in the engineering network. The source from measure is 949.46 and the source to measure is 3847.665. The target from measure is 949.46 and the target to measure is 9079.625. Use centerline 2902 valid on 01/01/2010. Use 'L7_Abandon' as the abandoned line name and use 'R34_Abandon' for the abandoned route name. Do not recalibrate downstream, and use 'NewRouteR1000' as the name for the new realigned route. | You are presented with the populated first page of the Realign Route pane. After you click Run, the subsequent pages of the Realign Route pane are also populated. |
| Route reassignment | Reassign a route. | If only one LRS Network is found on the map, you are asked to provide a route ID or route name. If multiple LRS Networks are found on the map, you are asked to specify an LRS Network. |
| Route reassignment | Reassign a route in the engineering network. The source from route is R1 with source from measure 1500. The source to route is R2 with source to measure 1000. Merge to adjacent route R3 as of 01/01/2024 with target from measure 0 and target to measure 2500. | The Reassign Route pane is populated. |
| Route reassignment | Reassign a route in the engineering network. The source from route is R1 with source from measure 0. The source to route is R2 with source to measure 3000. Transfer to another line 'Line005'. Update R1_Reassign with new name R1_A with measures 1500 to 3000. Update R2_Reassign with new name R2_A with measures 0 to 3000. |
You are presented with the populated first page of the Reassign Route pane. After you click Run, the subsequent pages of the Reassign Route pane are also populated. |
| Route extension | Extend a route. | If only one LRS Network is found on the map, you are asked to provide a route ID or route name. If multiple LRS Networks are found on the map, you are asked to specify an LRS Network. |
| Route extension | Extend route R1 in the county log network. | If the centerlines are selected on the map and touch the route, the Extend Route pane is populated. |
| Route retirement | Retire a route. | If only one LRS Network is found on the map, you are asked to provide a route ID or route name. If multiple LRS Networks are found on the map, you are asked to specify an LRS Network. |
| Route retirement | On 01/01/2010, retire route R1 from measures 0 to 2 in the county log network and recalibrate downstream. | The Retire Route pane is populated. |
If a message about locks appears in the Assistant (Beta) pane, it means that conflict prevention is enabled.
The following table includes synonyms that you can use when performing LRS route editing with the ArcGIS Pro assistant (beta):
| LRS terms | Synonyms | When to use |
| Route | Roadway, road, highway, datum | Any LRS route editing operation |
| Measure | Tie-in, connection point, station, stationing | Any LRS route editing operation |
| Create | Build, form, produce, generate, make, add, construct | Route creation |
| Reverse | Flip, change direction, change orientation, flip calibration direction, invert, swap | Route reversal |
| Realign | Reroute, reposition, reshape, reconstruct, reorient | Route realignment |
| Reassign | Merge, split, rename | Route reassignment |
| Extend | Expand, lengthen, elongate, continue | Route extension |
| Retire | Discontinue, decommission, deactivate, take out of service, retirement | Route retirement |
