ArcGIS.Desktop.Layouts Namespace / GroupElement Class
Members Example
    GroupElement Class
    Represents a group element that appears in the layout contents pane. Represents a group element
    Object Model
    GroupElement ClassCoordinate2D StructureEnvelope ClassCIMElement ClassGeometry ClassIElementContainer Interface
    Syntax
    Remarks
    It is possible that group elements can be nested in another group element. If the element container is a Layout then the element gets added to the root level of the layout TOC at the top most position. If the element container is a GroupElement then it gets added to the group at the topmost position.
    The FindElement method will also find elements nested in a group element.
    If you want to work with all the elements within a group element, use the Elements property to return the collection of elements in a group element.
    Example
    Creating empty group elements
      //Create an empty group element at the root level of the contents pane
      //Note: Must be on QueuedTask.Run
      //container is IElementContainer - GroupLayer or Layout
      GroupElement grp1 = ElementFactory.Instance.CreateGroupElement(
                            layout, null, "Group");
      // *** or ***
      //Create a group element inside another group element
      //Find an existing group element
      GroupElement existingGroup = layout.FindElement("Group") as GroupElement;
      //Create on worker thread
      GroupElement grp2 = ElementFactory.Instance.CreateGroupElement(
          existingGroup, null, "Group in Group");
    Create a group element with elements
      //Create a group with a list of elements at the root level of the contents pane.
      //Find an existing elements
      var elem1 = layout.FindElement("Polygon 1");
      var elem2 = layout.FindElement("Bezier Text");
      var elem3 = layout.FindElement("Cloud Shape 2");
      //Construct a list and add the elements
      var elmList = new List<Element>
        elem1,
        elem2,
        elem3
      GroupElement groupWithListOfElementsAtRoot =
                         layout, elmList, "Group with list of elements at root");
      // *** or ***
      //Create a group using a list of element names at the root level of the contents pane.
      //List of element names
      var elmNameList = new[] { "Para Text1", "Line 3" };
      var elemToGroup = layout.FindElements(elmNameList);
      GroupElement groupWithListOfElementNamesAtRoot =
                 layout, elemToGroup, "Group with list of element names at root");
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Layouts.Element
             ArcGIS.Desktop.Layouts.GroupElement
                ArcGIS.Desktop.Reports.ReportSectionElement
    Requirements
