ArcGIS.Core.Data Namespace / Geodatabase Class / Geodatabase Constructor / Geodatabase Constructor(FileGeodatabaseConnectionPath)
Holds a valid path to a file geodatabase folder that ends with the .gdb extension.
Example
    Opens a file geodatabase with the specified connectionPath. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    connectionPath
    Exceptions
    ExceptionDescription
    The path to the geodatabase is invalid or the geodatabase cannot be opened.
    A geodatabase-related exception has occurred.
    This object must be created within the lambda or delegate passed to QueuedTask.Run, or on a compatible STA thread.
    Example
    Opening a File Geodatabase given the path
      await QueuedTask.Run(() =>
        // Opens a file geodatabase. This will open the geodatabase if the folder exists and contains a valid geodatabase.
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\Data\LocalGovernment.gdb"))))
          // Use the geodatabase.
    Open raster dataset in a geodatabase
    // Create a FileGeodatabaseConnectionPath using the path to the gdb. Note: This can be a path to a .sde file.
    FileGeodatabaseConnectionPath geodatabaseConnectionPath = new(new Uri(@"C:\Temp\rasters.gdb"));
    // Create a new Geodatabase object using the FileGeodatabaseConnectionPath.
    Geodatabase geodatabase = new(geodatabaseConnectionPath);
    // Open the raster dataset.
    RasterDataset gdbRasterDataset = geodatabase.OpenDataset<RasterDataset>("sample");
    Requirements
