ArcGIS.Core.Data Namespace / FileSystemConnectionPath Class / FileSystemConnectionPath Constructor
A valid path to a specific file-system data store.
The type of file-system data store.
Example
    Opens a file-system data store with the specified path.
    Syntax
    Public Function New( _
       ByVal path As Uri, _
       ByVal type As FileSystemDatastoreType _
    public FileSystemConnectionPath(
       Uri path,
       FileSystemDatastoreType type
    Parameters
    path
    type
    Exceptions
    ExceptionDescription
    No valid file-system data store has been opened prior to invoking this operation.
    path is null.
    type is invalid.
    Example
    Opening a FeatureClass from a ShapeFile Datastore
      await QueuedTask.Run(() =>
        FileSystemConnectionPath fileConnection = new FileSystemConnectionPath(new Uri("path\\to\\folder\\containing\\shapefiles"),
            FileSystemDatastoreType.Shapefile);
        using (FileSystemDatastore shapefile = new FileSystemDatastore(fileConnection))
          FeatureClass taxLotsFeatureClass = shapefile.OpenDataset<FeatureClass>("TaxLots");
          // Can use the .shp extension, but its not needed.
          FeatureClass manHolesFeatureClass = shapefile.OpenDataset<FeatureClass>("ManHoles.shp");
          Table taxDetailsTableWithoutExtension = shapefile.OpenDataset<Table>("TaxDetails");
          Table taxDetailsTable = shapefile.OpenDataset<Table>("TaxDetails.dbf");
    Opening a CAD Datastore
        FileSystemConnectionPath fileConnection = new FileSystemConnectionPath(new Uri("path\\to\\folder\\containing\\CAD"), FileSystemDatastoreType.Cad);
        using (FileSystemDatastore cadDatastore = new FileSystemDatastore(fileConnection))
          //Note: Extension is required
          FeatureClass cadDataset = cadDatastore.OpenDataset<FeatureClass>("hatchplayboundaries.dwg");
          // Take note of the pattern for referencing a feature class.
          FeatureClass cadfeatureClass = cadDatastore.OpenDataset<FeatureClass>("hatchplayboundaries.dwg:Polyline");
          int numRows = 0;
          using (RowCursor cursor = cadfeatureClass.Search())
            while (cursor.MoveNext())
              numRows++;
    Open raster dataset in a folder
    // Create a FileSystemConnectionPath using the folder path.
    FileSystemConnectionPath connectionPath = new(new System.Uri(@"C:\Temp"), FileSystemDatastoreType.Raster);
    // Create a new FileSystemDatastore using the FileSystemConnectionPath.
    FileSystemDatastore dataStore = new(connectionPath);
    // Open the raster dataset.
    RasterDataset fileRasterDataset = dataStore.OpenDataset<RasterDataset>("Sample.tif");
    Requirements
