Public NotInheritable Class AttributeIndexDescription Inherits IndexDescription
public sealed class AttributeIndexDescription : IndexDescription
await QueuedTask.Run(() =>
using (var kg = GetKnowledgeGraph(url))
var entity_name = "PhoneCall";
//indexes are managed on the GDB objects...
var entity_table_def = kg.GetDefinition<TableDefinition>(entity_name);
var entity_table_desc = new TableDescription(entity_table_def);
var entity_table_flds = entity_table_def.GetFields();
AttributeIndexDescription attr_index1 = null;
AttributeIndexDescription attr_index2 = null;
foreach (var fld in entity_table_flds)
//index the first string field
if (fld.FieldType == FieldType.String && attr_index1 == null)
if (fld.Name == "ESRI__ID")//special case
continue;
//Index _must_ be ascending for KG
attr_index1 = new AttributeIndexDescription(
"Index1", entity_table_desc, new List<string> { fld.Name })
IsAscending = true
//index the first numeric field (if there is one)
if ((fld.FieldType == FieldType.BigInteger ||
fld.FieldType == FieldType.Integer ||
fld.FieldType == FieldType.Single ||
fld.FieldType == FieldType.SmallInteger ||
fld.FieldType == FieldType.Double) && attr_index2 == null)
attr_index2 = new AttributeIndexDescription(
"Index2", entity_table_desc, new List<string> { fld.Name })
IsAscending = true,
IsUnique = true //optional - unique if all values are to be unique in the index
if (attr_index1 != null && attr_index2 != null) break;
if (attr_index1 == null && attr_index2 == null)
return; //nothing to index
//Run the schema builder
try
SchemaBuilder sb = new(kg);
if (attr_index1 != null)
sb.Create(attr_index1);
if (attr_index2 != null)
sb.Create(attr_index2);
if (!kg.ApplySchemaEdits(sb))
var err_msg = string.Join(",", sb.ErrorMessages.ToArray());
System.Diagnostics.Debug.WriteLine($"Create index error: {err_msg}");
catch (Exception ex)
System.Diagnostics.Debug.WriteLine(ex.ToString());
var indexes = entity_table_def.GetIndexes();
foreach (var idx in indexes)
System.Diagnostics.Debug.WriteLine($"Index {idx.GetName()}");
var idx1 = indexes.FirstOrDefault(
idx => idx.GetName().ToLower() == "Index1".ToLower());
var idx2 = indexes.FirstOrDefault(
idx => idx.GetName().ToLower() == "Index2".ToLower());
if (idx1 == null && idx2 == null)
return;
try
if (idx1 != null)
var idx_attr = new AttributeIndexDescription(idx1, entity_table_desc);
sb.Delete(idx_attr);
if (idx2 != null)
var idx_attr = new AttributeIndexDescription(idx2, entity_table_desc);
System.Diagnostics.Debug.WriteLine($"Delete index error: {err_msg}");
System.Object
ArcGIS.Core.Data.DDL.Description
ArcGIS.Core.Data.DDL.IndexDescription
ArcGIS.Core.Data.DDL.AttributeIndexDescription
