Inheritance Hierarchy
    ArcGIS.Core.Data.DDL Namespace
    This namespace contains classes that support the data definition language (DDL) operations.
    Classes
     ClassDescription
    ClassRepresents a mechanism to create a ArcGIS.Core.Data.Mapping.AnnotationFeatureClass.
    ClassThe Token object to handle schema operations with a ArcGIS.Core.Data.Mapping.AnnotationFeatureClass.
    ClassRepresents a mechanism to create a ArcGIS.Core.Data.AttributedRelationshipClass.
    ClassThe Token object to handle schema operations with a ArcGIS.Core.Data.RelationshipClass.
    ClassRepresents a mechanism to create an attribute ArcGIS.Core.Data.Index.
    ClassRepresents a mechanism to create a ArcGIS.Core.Data.CodedValueDomain.
    ClassThe Token object to handle schema operations with a ArcGIS.Core.Data.CodedValueDomain.
    Class Represents a mechanism to create a dataset.
    ClassRepresents a mechanism to create a ArcGIS.Core.Data.Mapping.DimensionFeatureClass.
    ClassThe Token object to handle schema operations with a ArcGIS.Core.Data.Mapping.DimensionFeatureClass.
    ClassRepresents a mechanism to create a ArcGIS.Core.Data.Domain.
    ClassRepresents a mechanism to create a ArcGIS.Core.Data.FeatureClass.
    ClassThe Token object to handle schema operations with a ArcGIS.Core.Data.FeatureClass.
    ClassRepresents a mechanism to create a ArcGIS.Core.Data.FeatureDataset.
    ClassThe Token object to handle schema operations with a ArcGIS.Core.Data.Table.
    ClassRepresents a mechanism to create a ArcGIS.Core.Data.Field.
    ClassRepresents a mechanism to create an ArcGIS.Core.Data.Index.
    ClassRepresents a mechanism to create a ArcGIS.Core.Data.RangeDomain.
    ClassThe Token object to handle schema operations with a ArcGIS.Core.Data.RangeDomain.
    ClassRepresents a mechanism to create a ArcGIS.Core.Data.RelationshipClass.
    ClassRepresents a mechanism to create a ArcGIS.Core.Data.RelationshipRule.
    Class This class is used to perform all DDL (data definition language) tasks in the Pro SDK.
    ClassRepresents a mechanism to create a Shape ArcGIS.Core.Data.Field.
    ClassRepresents a mechanism to create a spatial ArcGIS.Core.Data.Index.
    ClassRepresents a mechanism to designate a ArcGIS.Core.Data.Field as the subtype field for a ArcGIS.Core.Data.Table.
    ClassRepresents a mechanism to create a ArcGIS.Core.Data.Table.
    Class An object that describes the result of an enqueued operation.
