// Must be called within QueuedTask.Run
void CreateFeatureDatasetWithFeatureClassSnippet(Geodatabase geodatabase)
// Creating a FeatureDataset named as 'Parcel_Information' and a FeatureClass with name 'Parcels' in one operation
string featureDatasetName = "Parcel_Information";
string featureClassName = "Parcels";
SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
// Create a FeatureDataset token
FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetName, SpatialReferences.WGS84);
FeatureDatasetToken featureDatasetToken = schemaBuilder.Create(featureDatasetDescription);
// Create a FeatureClass description
FeatureClassDescription featureClassDescription = new FeatureClassDescription(featureClassName,
new List<FieldDescription>()
new FieldDescription("Id", FieldType.Integer),
new FieldDescription("Address", FieldType.String)
new ShapeDescription(GeometryType.Point, SpatialReferences.WGS84));
// Create a FeatureClass inside a FeatureDataset
FeatureClassToken featureClassToken = schemaBuilder.Create(
new FeatureDatasetDescription(featureDatasetToken),
featureClassDescription);
// Build status
bool buildStatus = schemaBuilder.Build();
// Build errors
if (!buildStatus)
IReadOnlyList<string> errors = schemaBuilder.ErrorMessages;
System.Object
ArcGIS.Core.Data.DDL.Token
ArcGIS.Core.Data.DDL.FeatureDatasetToken
