ArcGIS.Core.Data.DDL Namespace / FeatureClassDescription Class
Members Example
    Represents a mechanism to create a ArcGIS.Core.Data.FeatureClass.
    Object Model
    FeatureClassDescription ClassShapeDescription ClassSubtypeFieldDescription Class
    Syntax
    Public Class FeatureClassDescription
       Inherits TableDescription
    public class FeatureClassDescription : TableDescription
    Example
    64-bit Integer field
      FieldDescription bigIntegerFieldDescription =
        new FieldDescription("BigInteger_64", FieldType.BigInteger);
    ObjectID field
      // 64-bit
      FieldDescription oidFieldDescription_64 =
        new FieldDescription("ObjectID_64", FieldType.OID)
          Length = 8
      // 32-bit
      FieldDescription oidFieldDescription_32 =
        new FieldDescription("ObjectID_32", FieldType.OID)
          Length = 4
    DateOnly, TimeOnly, and TimestampOffset field
      // Earthquake occurrences date and time
      // 9/28/2014 (DateOnly)
      FieldDescription earthquakeDateOnlyFieldDescription =
        new FieldDescription("Earthquake_DateOnly", FieldType.DateOnly);
      // 1:16:42 AM (TimeOnly)
      FieldDescription earthquakeTimeOnlyFieldDescription =
        new FieldDescription("Earthquake_TimeOnly", FieldType.TimeOnly);
      // 9/28/2014 1:16:42.000 AM -09:00 (Timestamp with Offset)
      FieldDescription earthquakeTimestampOffsetFieldDescription =
        new FieldDescription("Earthquake_TimestampOffset_Local", FieldType.TimestampOffset);
      // 9/28/2014 1:16:42 AM (DateTime)
      FieldDescription earthquakeDateFieldDescription =
        new FieldDescription("Earthquake_Date", FieldType.Date);
    Creating a FeatureDataset with a FeatureClass in one operation
      // Must be called within QueuedTask.Run
      void CreateFeatureDatasetWithFeatureClassSnippet(Geodatabase geodatabase)
        // Creating a FeatureDataset named as 'Parcel_Information' and a FeatureClass with name 'Parcels' in one operation
        string featureDatasetName = "Parcel_Information";
        string featureClassName = "Parcels";
        SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
        // Create a FeatureDataset token
        FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetName, SpatialReferences.WGS84);
        FeatureDatasetToken featureDatasetToken = schemaBuilder.Create(featureDatasetDescription);
        // Create a FeatureClass description
        FeatureClassDescription featureClassDescription = new FeatureClassDescription(featureClassName,
          new List<FieldDescription>()
              new FieldDescription("Id", FieldType.Integer),
              new FieldDescription("Address", FieldType.String)
          new ShapeDescription(GeometryType.Point, SpatialReferences.WGS84));
        // Create a FeatureClass inside a FeatureDataset
        FeatureClassToken featureClassToken = schemaBuilder.Create(
          new FeatureDatasetDescription(featureDatasetToken),
          featureClassDescription);
        // Build status
        bool buildStatus = schemaBuilder.Build();
        // Build errors
        if (!buildStatus)
          IReadOnlyList<string> errors = schemaBuilder.ErrorMessages;
    Creating a FeatureClass in existing FeatureDataset
      void CreateFeatureClassInsideFeatureDatasetSnippet(Geodatabase geodatabase)
        // Creating a FeatureClass named as 'Tax_Jurisdiction' in existing FeatureDataset with name 'Parcels_Information'
        string featureDatasetName = "Parcels_Information";
        string featureClassName = "Tax_Jurisdiction";
              new FieldDescription("Tax_Id", FieldType.Integer),
        FeatureDatasetDefinition featureDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>(featureDatasetName);
        // Create a FeatureClass inside a FeatureDataset using a FeatureDatasetDefinition
        schemaBuilder.Create(new FeatureDatasetDescription(featureDatasetDefinition), featureClassDescription);
        // Build status
        // Build errors
        if (!buildStatus)
    Adding a Field that uses a domain
      void AddFieldWithDomainSnippet(Geodatabase geodatabase)
        //The FeatureClass to add field
        string featureClassName = "Pipes";
        // Create a CodedValueDomain description for water pipes
        CodedValueDomainDescription pipeDomainDescription = new CodedValueDomainDescription("WaterPipeTypes",
          FieldType.String, new SortedList<object, string>
              { "C_1", "Copper" },
              { "S_2", "Steel" }
          SplitPolicy = SplitPolicy.Duplicate,
          MergePolicy = MergePolicy.DefaultValue
        // Create a coded value domain token
        CodedValueDomainToken codedValueDomainToken = schemaBuilder.Create(pipeDomainDescription);
        // Create a new description from domain token
        CodedValueDomainDescription codedValueDomainDescription = new CodedValueDomainDescription(codedValueDomainToken);
        // Create a field named as 'PipeType' using a domain description
        FieldDescription domainFieldDescription = new FieldDescription("PipeType", FieldType.String);
        domainFieldDescription.SetDomainDescription(codedValueDomainDescription);
        //Retrieve existing information for 'Pipes' FeatureClass
        FeatureClassDefinition originalFeatureClassDefinition = geodatabase.GetDefinition<FeatureClassDefinition>(featureClassName);
        FeatureClassDescription originalFeatureClassDescription =
          new FeatureClassDescription(originalFeatureClassDefinition);
        // Add domain field on existing fields
        // Adding a field,'PipeType', which uses the coded value domain to the 'Pipes' FeatureClass
        List<FieldDescription> modifiedFieldDescriptions = new List<FieldDescription>(originalFeatureClassDescription.FieldDescriptions)
          { domainFieldDescription };
        // Create a new description with updated fields for 'Pipes' FeatureClass
        FeatureClassDescription featureClassDescription = new FeatureClassDescription(originalFeatureClassDescription.Name, modifiedFieldDescriptions,
          originalFeatureClassDescription.ShapeDescription);
        // Update the 'Pipes' FeatureClass with domain field
        schemaBuilder.Modify(featureClassDescription);
        // Build status
        // Build errors
        if (!buildStatus)
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Data.DDL.Description
          ArcGIS.Core.Data.DDL.TableDescription
             ArcGIS.Core.Data.DDL.FeatureClassDescription
                ArcGIS.Core.Data.DDL.AnnotationFeatureClassDescription
                ArcGIS.Core.Data.DDL.DimensionFeatureClassDescription
    Requirements
