ArcGIS.Desktop.Core Namespace / Item Class / GetXml Method
Example
    GetXml Method (Item)
    Gets the item’s metadata XML document as a string. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetXml() As String
    public string GetXml()
    Return Value
    Metadata xml string
    Exceptions
    ExceptionDescription
    Remarks
    Not all items support metadata. Be sure to check for empty string or null as the return value from GetXml.
    Example
    Item: Get an item's metadata: GetXML
      string gdbXMLMetadataXmlAsString = string.Empty;
      // Note: Needs QueuedTask to run
      gdbXMLMetadataXmlAsString = gdbMetadataItem.GetXml();
      //check metadata was returned
      if (!string.IsNullOrEmpty(gdbXMLMetadataXmlAsString))
        //use the metadata
    Requirements
