| Name | Description | |
![]() | Item Constructor | Overloaded. |
The following tables list the members exposed by Item.
![]() | AccessConstraints | Gets documented limitations with respect to using the item. Derived from Use Limitations defined in the item's metadata. |
![]() | Alias | Gets and sets the alias of the item. The setter for this property changes the value for this application session, but will not result in the new value being persisted for the next session even if changes to the project are saved. If the new value needs to be saved with other project changes, use the SetAlias method. |
![]() | Credits | Gets information that gives credit to the producer or provider of the item. Derived from Credits defined in the item's metadata. |
![]() | Description | Gets and sets a description of the item. Derived from the Description or Abstract defined in the item's metadata. |
![]() | FileSize | Gets the item file size |
![]() | Guid | Gets a unique identifier for the item |
![]() | ID | Gets a unique identifier associated with each portal item |
![]() | IsContainer | Gets if the item contains other items |
![]() | IsDefault | Gets if the item has been set as a default for this project |
![]() | IsInvalid | Gets if the item is invalid |
![]() | IsInvalidReason | Get the reason that the item is invalid |
![]() | IsMainThreadRequired | Returns whether the Item must be refreshed on the MCT within the lambda of a QueuedTask.Run. |
![]() | ItemCategories | Gets a list of the item categories in which the item participates |
![]() | MaxScale | Gets the maximum map scale at which the item should draw |
![]() | MinScale | Gets the minimum map scale at which the item should draw |
![]() | Name | Gets and sets the name of the item |
![]() | Path | Gets the path used to access the item |
![]() | PhysicalPath | Gets and sets the location where the item is stored |
![]() | SourceModifiedTime | Gets and sets the time when the item's source item was last modified |
![]() | SourceUri | Gets and sets a Uri that identifies the source item from which the item was created in the project |
![]() | Summary | Gets and sets a summary describing the purpose of the item. Derived from the Summary or Purpose defined in the item's metadata. |
![]() | Tags | Gets and sets a comma-separated list of tags that describe the item. Derived from Tags defined in the item's metdata. |
![]() | ThumbnailPath | Gets and sets a path to a thumbnail that describes and helps to identify the item. Derived from the Thumbnail that is extracted from the item's metadata. |
![]() | Title | Gets and sets a descriptive title for the item. Derived from the Title in the item's metadata. |
![]() | Type | Gets a localized string indicating the item's type, for example, shapefile |
![]() | TypeID | Gets the type identifier that indicates what icon, context menu, and operations the item should have |
![]() | TypeKeywords | Gets keywords associated with the item's type that support finding the item with a search |
![]() | Url | Gets a URL that can be used to access the item |
![]() | XMax | Gets the maximum value along the x-axis for the item's minimum bounding rectangle |
![]() | XMin | Gets the minimum value along the x-axis for the item's minimum bounding rectangle |
![]() | YMax | Gets the maximum value along the y-axis for the item's minimum bounding rectangle |
![]() | YMin | Gets the minimum value along the y-axis for the item's minimum bounding rectangle |
![]() | BlockFromCache | Gets whether to block from the cache |
![]() | Category | Gets the category for this item |
![]() | ContainerType | Gets and sets the container type for this item |
![]() | ContextMenuID | Gets and sets the context menu id for the item |
![]() | CreatedTime | Gets the item creation time |
![]() | DataLastModifiedTime | Gets and sets the last modified time for this item |
![]() | DisplayType | Gets and sets the display type string |
![]() | GroupSortOrder | Gets and sets the group sort order for the item. |
![]() | HasChildren | Checks whether the item has child items in its child item collection |
![]() | IsSearchable | Gets whether the item is searchable. Default is true |
![]() | Key | Gets the associated key for this item |
![]() | SortOrder | Gets and sets the project item sort order for the item. |
![]() | SupportsCategories | Gets whether the item supports categories. The default is false |
![]() | SupportsDateType | Gets whether the item supports a date. The default is true |
![]() | SupportsOwner | Gets whether the item supports an owner. The default is false |
![]() | CanEdit | Indicates if metadata is editable for the item. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | CopyMetadataFromItem | Copy metadata from Item. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | DeleteMetadataContent | Delete certain content from the metadata of the current item. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | Equals | Determines if the given object is identical to this object. |
![]() | ExportMetadata | Overloaded. |
![]() | GetHashCode | Gets a hash code associated with this item. |
![]() | GetItems | Browses the contents of an item. Returns a snapshot collection of of the item's children. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | GetXml | Gets the item’s metadata XML document as a string. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | ImportMetadata | Overloaded. |
![]() | OnCurrentRoot | Called when the Item becomes the current root item in the Catalog View. |
![]() | OnExpanded | Override to implement any custom logic when your item is expanded |
![]() | Refresh | Refreshes the collection of children. Use IsMainThreadRequired to determine the correct thread for performing a refresh. |
![]() | Repair | Repair the path |
![]() | SaveMetadataAsHTML | Save the metadata of the current item as HTML. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | SaveMetadataAsUsingCustomXSLT | Save the metadata of the current item using customized XSLT. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | SaveMetadataAsXML | Save the metadata of the current item as XML. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | SearchItem | Search |
![]() | SetAlias | Changes the alias value on the given item. This method will return false if the item is not a folder connection. |
![]() | SetXml | Sets the item’s metadata to the XML document provided as a string. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | Synchronize | Updates metadata with the current properties of the item. Metadata is created for the item if it doesn't already exist. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | ToString | Override the default ToString() method. |
![]() | UpgradeMetadata | Upgrade the metadata of the current item. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | AddRangeToChildren | Adds the collection of items to the item's child collection |
![]() | ClearChildren | Removes all items from the item's child collection |
![]() | GetChildren | Gets the children of this item |
![]() | GetContainerType | Gets the container type |
![]() | GetRepairPath | Gets the repair path |
![]() | HasChild | Check if the item contains the specified child item in its child collection |
![]() | InsertChild | Insert the child item into the item's child collection at the specified index |
![]() | NotifyPropertyChanged | Overloaded. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase) |
![]() | OnFolderRename | Callback when an item's parent folder is being renamed |
![]() | RemoveChild | Remove the specified item from the item's child collection |
![]() | RemoveRangeFromChildren | Remove the collection of items from the item's child collection |
![]() | SetProperty | Overloaded. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase) |
![]() | UnlinkPortalItem | Derived classes can override this method |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase) |
