ArcGIS.Core.Data Namespace / TableDefinition Class / GetAttributeRules Method
The attribute type to return. Use AttributeRuleType.All to obtain all rule types.
Example
    Gets a IReadOnlyList of the table's attribute rules. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    attributeRuleType
    Return Value
    A IReadOnlyList of the table's attribute rules.
    Exceptions
    ExceptionDescription
    The definition does not support this operation (e.g., the table is a shapefile).
    A geodatabase-related exception has occurred.
    Example
    Evaluate AttributeRule Expression
      //Consult https://github.com/Esri/arcade-expressions/ and
      //https://developers.arcgis.com/arcade/profiles/attribute-rules/ for
      //more examples and arcade reference
      // Note: the following should be embedded in a QueuedTask.Run() statement
        //Retrieve the desired feature class/table
        FeatureClassDefinition def = featureLayer.GetFeatureClass().GetDefinition();
        //get the desired attribute rule whose expression is to be evaluated.
        //AttributeRuleType.All, Calculation, Constraint, Validation
        AttributeRuleDefinition validation_rule = def.GetAttributeRules(
                                                  AttributeRuleType.Validation).FirstOrDefault();
        if (validation_rule == null)
          return;
        //Get the expression
        var expr = validation_rule.GetScriptExpression();
        //construct a CIMExpressionInfo
        var arcade_expr = new CIMExpressionInfo()
          Expression = expr,
          //Return type can be string, numeric, or default
          ReturnType = ExpressionReturnType.Default
        System.Diagnostics.Debug.WriteLine($"Evaluating {expr}:");
        //Construct an evaluator
        //we are using ArcadeProfile.AttributeRules profile...
        //Consult: https://developers.arcgis.com/arcade/profiles/
        using var arcade = ArcadeScriptEngine.Instance.CreateEvaluator(
                                arcade_expr, ArcadeProfile.AttributeRuleValidation);
        //we are evaluating the expression against all features
        using var rc = featureLayer.Search();
        while (rc.MoveNext())
          // Provision  values for any profile variables referenced...
          // we assume '$feature' here
          //...use arcade.ProfileVariablesUsed() if necessary...
          var variables = new List<KeyValuePair<string, object>>() {
              new("$feature", rc.Current)
          //evaluate the expression per feature
          try
            var result = arcade.Evaluate(variables).GetResult();
            //'Validation' attribute rules return true or false...
            var valid = bool.Parse(result.ToString());
              $"{rc.Current.GetObjectID()} valid: {valid}");
          //handle any exceptions
          catch (InvalidProfileVariableException)
            //something wrong with the profile variable specified
            //TODO...
          catch (EvaluationException)
            //something wrong with the query evaluation
            //TODO...
    Get attribute rules of a dataset
      // Must be called within QueuedTask.Run
      void GetAttributeRules(Geodatabase geodatabase, string tableName)
        using (TableDefinition tableDefinition = geodatabase.GetDefinition<TableDefinition>(tableName))
          // Get all attribute rule types
          IReadOnlyList<AttributeRuleDefinition> ruleDefinitions = tableDefinition.GetAttributeRules();
          // Iterate rule definitions
          foreach (AttributeRuleDefinition ruleDefinition in ruleDefinitions)
            AttributeRuleType ruleType = ruleDefinition.GetAttributeRuleType();
            string ruleDescription = ruleDefinition.GetDescription();
            bool isAttributeFieldEditable = ruleDefinition.GetIsFieldEditable();
            string arcadeVersionToSupportRule = ruleDefinition.GetMinimumArcadeVersion();
            int ruleEvaluationOrder = ruleDefinition.GetEvaluationOrder();
            AttributeRuleTriggers triggeringEvents = ruleDefinition.GetTriggeringEvents();
            string scriptExpression = ruleDefinition.GetScriptExpression();
            // More properties ...
    Requirements
    ArcGIS Pro version: 3.2 or higher.
