ArcGIS.Core.Data Namespace / TableDefinition Class
Members Example
    Represents the schema and properties of a Table.
    Syntax
    Public Class TableDefinition
       Inherits Definition
       Implements System.IDisposable
    public class TableDefinition : Definition, System.IDisposable
    Example
    Obtaining Definition from Geodatabase
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
          // Remember that for Enterprise databases you have to qualify your dataset names with the DatabaseName and UserName.
          TableDefinition enterpriseTableDefinition = geodatabase.GetDefinition<TableDefinition>("LocalGovernment.GDB.CitizenContactInfo");
          // It does not matter if the dataset is within a FeatureDataset or not.
          FeatureClassDefinition featureClassDefinition = geodatabase.GetDefinition<FeatureClassDefinition>("LocalGovernment.GDB.FireStation");
          // GetDefinition For a RelationshipClass.
          RelationshipClassDefinition relationshipClassDefinition = geodatabase.GetDefinition<RelationshipClassDefinition>(
              "LocalGovernment.GDB.AddressPointHasSiteAddresses");
          // GetDefinition For a FeatureDataset.
          FeatureDatasetDefinition featureDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>("LocalGovernment.GDB.Address");
    Obtaining List of Definitions from Geodatabase
          IReadOnlyList<FeatureClassDefinition> enterpriseDefinitions = geodatabase.GetDefinitions<FeatureClassDefinition>();
          IEnumerable<Definition> featureClassesHavingGlobalID = enterpriseDefinitions.Where(definition => definition.HasGlobalID());
          IReadOnlyList<FeatureDatasetDefinition> featureDatasetDefinitions = geodatabase.GetDefinitions<FeatureDatasetDefinition>();
          bool electionRelatedFeatureDatasets = featureDatasetDefinitions.Any(definition => definition.GetName().Contains("Election"));
          IReadOnlyList<AttributedRelationshipClassDefinition> attributedRelationshipClassDefinitions = geodatabase.GetDefinitions<AttributedRelationshipClassDefinition>();
          IReadOnlyList<RelationshipClassDefinition> relationshipClassDefinitions = geodatabase.GetDefinitions<RelationshipClassDefinition>();
    Obtaining Definitions from a Feature Service by Layer ID
      //Url examples for (federated) feature services
      //(by "ref" online):
      var url =
          @"https://sampleserver6.arcgisonline.com/arcgis/rest/services/SF311/FeatureServer";
      //(federated by ref on portal)
      //https://portal.example.com/server/rest/services/FeatureServiceName/FeatureServer");
      //(federated by value - Hosted - on portal)
      //https://portal.example.com/server/rest/services/Hosted/FeatureServiceName/FeatureServer");
        var uri = new Uri(url, UriKind.Absolute);
        using (var fs_db = new ArcGIS.Core.Data.Geodatabase(new ServiceConnectionProperties(uri)))
          //Assuming that id 0 is a FeatureClass for the given service
              fs_db.GetDefinition<FeatureClassDefinition>("0");
          string shapeField = featureClassDefinition.GetShapeField();
          IReadOnlyList<Field> fields = featureClassDefinition.GetFields();
          //Assuming that id 1 is a Table for the given service
          TableDefinition tableDefinition =
                fs_db.GetDefinition<TableDefinition>("1");
          string objectIDField = tableDefinition.GetObjectIDField();
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
          ArcGIS.Core.Data.Definition
             ArcGIS.Core.Data.TableDefinition
                ArcGIS.Core.Data.FeatureClassDefinition
                ArcGIS.Core.Data.Realtime.RealtimeTableDefinition
    Requirements
