Public Class FeatureClassDefinition Inherits TableDefinition Implements System.IDisposable
public class FeatureClassDefinition : TableDefinition, System.IDisposable
await QueuedTask.Run(() =>
using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
// Remember that for Enterprise databases you have to qualify your dataset names with the DatabaseName and UserName.
TableDefinition enterpriseTableDefinition = geodatabase.GetDefinition<TableDefinition>("LocalGovernment.GDB.CitizenContactInfo");
// It does not matter if the dataset is within a FeatureDataset or not.
FeatureClassDefinition featureClassDefinition = geodatabase.GetDefinition<FeatureClassDefinition>("LocalGovernment.GDB.FireStation");
// GetDefinition For a RelationshipClass.
RelationshipClassDefinition relationshipClassDefinition = geodatabase.GetDefinition<RelationshipClassDefinition>(
"LocalGovernment.GDB.AddressPointHasSiteAddresses");
// GetDefinition For a FeatureDataset.
FeatureDatasetDefinition featureDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>("LocalGovernment.GDB.Address");
IReadOnlyList<FeatureClassDefinition> enterpriseDefinitions = geodatabase.GetDefinitions<FeatureClassDefinition>();
IEnumerable<Definition> featureClassesHavingGlobalID = enterpriseDefinitions.Where(definition => definition.HasGlobalID());
IReadOnlyList<FeatureDatasetDefinition> featureDatasetDefinitions = geodatabase.GetDefinitions<FeatureDatasetDefinition>();
bool electionRelatedFeatureDatasets = featureDatasetDefinitions.Any(definition => definition.GetName().Contains("Election"));
IReadOnlyList<AttributedRelationshipClassDefinition> attributedRelationshipClassDefinitions = geodatabase.GetDefinitions<AttributedRelationshipClassDefinition>();
IReadOnlyList<RelationshipClassDefinition> relationshipClassDefinitions = geodatabase.GetDefinitions<RelationshipClassDefinition>();
//Url examples for (federated) feature services
//(by "ref" online):
var url =
@"https://sampleserver6.arcgisonline.com/arcgis/rest/services/SF311/FeatureServer";
//(federated by ref on portal)
//https://portal.example.com/server/rest/services/FeatureServiceName/FeatureServer");
//(federated by value - Hosted - on portal)
//https://portal.example.com/server/rest/services/Hosted/FeatureServiceName/FeatureServer");
var uri = new Uri(url, UriKind.Absolute);
using (var fs_db = new ArcGIS.Core.Data.Geodatabase(new ServiceConnectionProperties(uri)))
//Assuming that id 0 is a FeatureClass for the given service
fs_db.GetDefinition<FeatureClassDefinition>("0");
string shapeField = featureClassDefinition.GetShapeField();
IReadOnlyList<Field> fields = featureClassDefinition.GetFields();
//Assuming that id 1 is a Table for the given service
TableDefinition tableDefinition =
fs_db.GetDefinition<TableDefinition>("1");
string objectIDField = tableDefinition.GetObjectIDField();
// Remember the qualification of DatabaseName. for the RelationshipClass.
RelationshipClassDefinition enterpriseDefinition = geodatabase.GetDefinition<RelationshipClassDefinition>("LocalGovernment.GDB.AddressPointHasSiteAddresses");
IReadOnlyList<Definition> enterpriseDefinitions = geodatabase.GetRelatedDefinitions(enterpriseDefinition,
DefinitionRelationshipType.DatasetsRelatedThrough);
FeatureClassDefinition enterpriseAddressPointDefinition = enterpriseDefinitions.First(defn => defn.GetName().Equals("LocalGovernment.GDB.AddressPoint"))
as FeatureClassDefinition;
IReadOnlyList<Definition> datasetsInAddressDataset = geodatabase.GetRelatedDefinitions(featureDatasetDefinition,
DefinitionRelationshipType.DatasetInFeatureDataset);
FeatureClassDefinition addressPointInAddressDataset = datasetsInAddressDataset.First(defn => defn.GetName().Equals("LocalGovernment.GDB.AddressPoint"))
RelationshipClassDefinition addressPointHasSiteAddressInAddressDataset = datasetsInAddressDataset.First(defn =>
defn.GetName().Equals("LocalGovernment.GDB.AddressPointHasSiteAddresses"))
as RelationshipClassDefinition;
//Must be called within QueuedTask.Run()
RowCursor SortWorldCities(FeatureClass worldCitiesTable)
using (FeatureClassDefinition featureClassDefinition = worldCitiesTable.GetDefinition())
Field countryField = featureClassDefinition.GetFields()
.First(x => x.Name.Equals("COUNTRY_NAME"));
Field cityNameField = featureClassDefinition.GetFields()
.First(x => x.Name.Equals("CITY_NAME"));
// Create SortDescription for Country field
SortDescription countrySortDescription = new SortDescription(countryField);
countrySortDescription.CaseSensitivity = CaseSensitivity.Insensitive;
countrySortDescription.SortOrder = SortOrder.Ascending;
// Create SortDescription for City field
SortDescription citySortDescription = new SortDescription(cityNameField);
citySortDescription.CaseSensitivity = CaseSensitivity.Insensitive;
citySortDescription.SortOrder = SortOrder.Ascending;
// Create our TableSortDescription
TableSortDescription tableSortDescription = new TableSortDescription(
new List<SortDescription>() { countrySortDescription, citySortDescription });
return worldCitiesTable.Sort(tableSortDescription);
System.Object
ArcGIS.Core.CoreObjectsBase
ArcGIS.Core.Data.Definition
ArcGIS.Core.Data.TableDefinition
ArcGIS.Core.Data.FeatureClassDefinition
ArcGIS.Core.Data.LinearReferencing.RouteEventSourceDefinition
ArcGIS.Core.Data.Mapping.AnnotationFeatureClassDefinition
ArcGIS.Core.Data.Mapping.CatalogDatasetDefinition
ArcGIS.Core.Data.Mapping.DimensionFeatureClassDefinition
ArcGIS.Core.Data.Realtime.RealtimeFeatureClassDefinition
