Public NotInheritable Class DimensionFeatureClassDefinition Inherits ArcGIS.Core.Data.FeatureClassDefinition Implements System.IDisposable
public sealed class DimensionFeatureClassDefinition : ArcGIS.Core.Data.FeatureClassDefinition, System.IDisposable
// Must be called within QueuedTask.Run
void CreateDimensionFeatureClass(Geodatabase geodatabase)
// Dimension feature class name
string dimensionFeatureClassName = "LineInfo";
// Create user defined attribute fields for dimension feature class
FieldDescription nameFieldDescription = new FieldDescription("Name", FieldType.String);
FieldDescription distanceFieldDescription = new FieldDescription("DistanceMeasure", FieldType.Double);
FieldDescription measurementDateFieldDescription = new FieldDescription("MeasurementDate", FieldType.Date);
// Create a list of all field descriptions
List<FieldDescription> fieldDescriptions = new List<FieldDescription>
{ nameFieldDescription, distanceFieldDescription, measurementDateFieldDescription };
// Create a ShapeDescription object
ShapeDescription shapeDescription = new ShapeDescription(GeometryType.Polygon, SpatialReferences.WGS84);
// Create a SchemaBuilder object
SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
// Create DimensionFeatureClassDescription object
DimensionFeatureClassDescription dimensionFeatureClassDescription = new DimensionFeatureClassDescription(
dimensionFeatureClassName, fieldDescriptions,
shapeDescription, GetCIMDimensionStyles());
// Token
DimensionFeatureClassToken dimensionFeatureClassToken =
schemaBuilder.Create(dimensionFeatureClassDescription);
// Execute the DDL
bool success = schemaBuilder.Build();
// Inspect error messages
if (!success)
IReadOnlyList<string> errorMessages = schemaBuilder.ErrorMessages;
//etc.
List<CIMDimensionStyle> GetCIMDimensionStyles()
CIMColor color = CIMColor.CreateRGBColor(10, 20, 30);
CIMPointSymbol beginMarkerSymbol = GetMarkerSymbol(color);
CIMPointSymbol endMarkerSymbol = GetMarkerSymbol(color);
CIMLineSymbol dimensionLineSymbol = GetLineSymbol(color, 0.5);
CIMLineSymbol extensionLineSymbol = GetLineSymbol(color, 0.5);
CIMTextSymbol textSymbol = GetDefaultTextSymbol(10);
textSymbol.Symbol = GetPolygonSymbol(color, color, 0);
textSymbol.HorizontalAlignment = HorizontalAlignment.Center;
CIMDimensionStyle cimDimensionStyle = new CIMDimensionStyle()
Name = "Style 1",
ID = 0,
Align = true,
DisplayUnits = null,
DisplayPrecision = 0,
BeginMarkerSymbol = beginMarkerSymbol,
EndMarkerSymbol = endMarkerSymbol,
MarkerOption = DimensionPartOptions.Both,
MarkerFit = DimensionMarkerFit.Text,
DimensionLineSymbol = dimensionLineSymbol,
DimensionLineOption = DimensionPartOptions.Both,
DrawLineOnFit = false,
ExtendLineOnFit = true,
BaselineHeight = 0.0,
ExtensionLineSymbol = extensionLineSymbol,
ExtensionLineOption = DimensionPartOptions.Both,
ExtensionLineOvershot = 0.0,
ExtensionLineOffset = 0.0,
Expression = "",
ExpressionParserName = "Arcade",
TextSymbol = textSymbol,
TextOption = DimensionTextOption.Only,
TextFit = DimensionTextFit.MoveBegin,
List<CIMDimensionStyle> cimDimensionStyles = [cimDimensionStyle];
return cimDimensionStyles;
CIMFill DefaultFill(CIMColor color)
return new CIMSolidFill()
Enable = true,
Name = "Fill_" + Guid.NewGuid().ToString(),
ColorLocked = false,
Color = color
CIMStroke DefaultStroke(CIMColor color, double width = 1)
return new CIMSolidStroke()
Color = color,
Name = "Stroke_" + Guid.NewGuid().ToString(),
CapStyle = LineCapStyle.Round,
JoinStyle = LineJoinStyle.Round,
CloseCaps3D = false,
LineStyle3D = Simple3DLineStyle.Strip,
MiterLimit = 4,
Width = width,
Enable = true,
CIMPolygonSymbol GetPolygonSymbol(CIMColor fillColor, CIMColor outlineColor, double outlineWidth)
if ((outlineColor == null) || (outlineWidth <= 0))
return new CIMPolygonSymbol() { SymbolLayers = new CIMSymbolLayer[1] { DefaultFill(fillColor) } };
SymbolLayers = new CIMSymbolLayer[2]
{ DefaultStroke(outlineColor, outlineWidth), DefaultFill(fillColor) }
CIMLineSymbol GetLineSymbol(CIMColor color, double width)
CIMStroke stroke = DefaultStroke(color, width);
return new CIMLineSymbol() { SymbolLayers = new CIMSymbolLayer[1] { stroke } };
Polygon CreateArrowGeometry()
double x = 2.39;
double y = 1.20;
double xMod = 0.3;
Coordinate2D pt1 = new Coordinate2D() { X = -x + xMod, Y = -y };
Coordinate2D pt2 = new Coordinate2D() { X = x + xMod, Y = 0 };
Coordinate2D pt3 = new Coordinate2D() { X = -x + xMod, Y = y };
List<Coordinate2D> coords = new List<Coordinate2D>() { pt1, pt2, pt3 };
Polygon polygon = PolygonBuilderEx.CreatePolygon(coords);
return polygon;
CIMPointSymbol GetMarkerSymbol(CIMColor color)
CIMMarkerGraphic graphic = new CIMMarkerGraphic()
Geometry = CreateArrowGeometry(),
Symbol = new CIMPolygonSymbol()
new CIMSolidFill()
Enable = true,
Color = color,
UseRealWorldSymbolSizes = false
CIMSymbolLayer symbolLayer = new CIMVectorMarker()
Enable = true,
Size = 12,
Frame = new EnvelopeBuilderEx() { XMin = -5, YMin = -3, XMax = 5, YMax = 3 }.ToGeometry() as Envelope,
MarkerGraphics = new CIMMarkerGraphic[1] { graphic },
ScaleSymbolsProportionally = true,
RespectFrame = true
return new CIMPointSymbol()
SymbolLayers = new CIMSymbolLayer[1] { symbolLayer },
HaloSize = 1,
ScaleX = 1,
AngleAlignment = AngleAlignment.Map,
CIMTextSymbol GetDefaultTextSymbol(double height)
return new CIMTextSymbol()
DrawGlyphsAsGeometry = false,
DrawSoftHyphen = false,
ExtrapolateBaselines = true,
FlipAngle = 0.0,
IndentAfter = 0.0,
IndentBefore = 0.0,
IndentFirstLine = 0.0,
Kerning = true,
LetterSpacing = 0.0,
LetterWidth = 100.0,
Ligatures = true,
LineGap = 0.0,
LineGapType = LineGapType.ExtraLeading,
Underline = false,
Strikethrough = false,
OffsetX = 0.0,
OffsetY = 0.0,
FontFamilyName = "Tahoma",
FontStyleName = "Regular",
WordSpacing = 100.0,
Height = height
System.Object
ArcGIS.Core.CoreObjectsBase
ArcGIS.Core.Data.Definition
ArcGIS.Core.Data.TableDefinition
ArcGIS.Core.Data.Mapping.DimensionFeatureClassDefinition
