ArcGIS.Core.Data.Analyst3D Namespace / LasDataset Class / GetFiles Method
Example
    GetFiles Method
    Gets the list of LasFile used in this LAS dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetFiles() As IReadOnlyList(Of LasFile)
    public IReadOnlyList<LasFile> GetFiles()
    Return Value
    An IReadOnlyList of LasFile.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Get Individual File Information from a LAS Dataset
      var (lasFileCount, zLasFileCount) = lasDataset.GetFileCounts();
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.LasFile> fileInfo = lasDataset.GetFiles();
      foreach (var file in fileInfo)
        var pathFile = file.FilePath;
        var name = file.FileName;
        var ptCount = file.PointCount;
        var zMin = file.ZMin;
        var zMax = file.ZMax;
    Requirements
    ArcGIS Pro version: 3.2 or higher.
