ArcGIS.Core.Data.Analyst3D Namespace / LasDatasetDefinition Class
Members Example
    Represents the properties of a LasDataset.
    Object Model
    LasDatasetDefinition ClassEnvelope ClassSpatialReference Class
    Syntax
    Public NotInheritable Class LasDatasetDefinition
       Inherits ArcGIS.Core.Data.Definition
       Implements System.IDisposable
    public sealed class LasDatasetDefinition : ArcGIS.Core.Data.Definition, System.IDisposable
    Example
    Get a LAS Dataset Defintion
      //Note: Use QueuedTask.Run to run on the MCT
      string path = @"d:\Data\LASDataset";
      var fileConnection = new FileSystemConnectionPath(new Uri(path), FileSystemDatastoreType.LasDataset);
      using (FileSystemDatastore dataStore = new FileSystemDatastore(fileConnection))
        string name = "utrecht_tile.lasd";      // can specify with or without the .lasd extension
        using (var dataset = dataStore.GetDefinition<ArcGIS.Core.Data.Analyst3D.LasDatasetDefinition>(name))
          //Use the dataset
    Retrieve dataset objects
      //Note: Needs QueuedTask to run
        using (var tin = tinLayer.GetTinDataset())
          using var tinDef = tin.GetDefinition();
          Envelope extent = tinDef.GetExtent();
          SpatialReference sr = tinDef.GetSpatialReference();
        using (terrain = terrainLayer.GetTerrain())
          using var terrainDef = terrain.GetDefinition();
          Envelope extent = terrainDef.GetExtent();
          SpatialReference sr = terrainDef.GetSpatialReference();
        using (lasDataset = lasDatasetLayer.GetLasDataset())
          using var lasDatasetDef = lasDataset.GetDefinition();
          Envelope extent = lasDatasetDef.GetExtent();
          SpatialReference sr = lasDatasetDef.GetSpatialReference();
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
    Requirements
    ArcGIS Pro version: 3.2 or higher.
