ArcGIS.Core.Data.Analyst3D Namespace / Terrain Class / GetDataSources Method
Example
    Gets the list of TerrainDataSource used in this terrain. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetDataSources() As IReadOnlyList(Of TerrainDataSource)
    public IReadOnlyList<TerrainDataSource> GetDataSources()
    Return Value
    An IReadOnlyList of TerrainDataSource.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Get datasources from a Terrain
      var dsCount = terrainDataset.GetDataSourceCount();
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TerrainDataSource> dataSources = terrainDataset.GetDataSources();
      foreach (var ds in dataSources)
        var dsName = ds.DataSourceName;
        var surfaceType = ds.SurfaceType;
        var maxResolution = ds.MaximumResolution;
        var minResolution = ds.MinimumResolution;
    Requirements
    ArcGIS Pro version: 3.2 or higher.
