ArcGIS.Core.Data.Analyst3D Namespace / Terrain Class / GetFeatureDataset Method
    GetFeatureDataset Method (Terrain)
    Gets the ArcGIS.Core.Data.FeatureDataset in which this terrain is contained. This method must be called on the MCT. Use QueuedTask.Run
    Syntax
    Public Function GetFeatureDataset() As FeatureDataset
    public FeatureDataset GetFeatureDataset()
    Return Value
    The parent ArcGIS.Core.Data.FeatureDataset of which this terrain is a member; otherwise, null.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
    ArcGIS Pro version: 3.2 or higher.
