ArcGIS.Core.Data.Analyst3D Namespace / TerrainDefinition Class
Members Example
    Represents the properties of a Terrain.
    Object Model
    TerrainDefinition ClassEnvelope ClassTerrainWindowSizeProperties ClassSpatialReference Class
    Syntax
    Public NotInheritable Class TerrainDefinition
       Inherits ArcGIS.Core.Data.Definition
       Implements System.IDisposable
    public sealed class TerrainDefinition : ArcGIS.Core.Data.Definition, System.IDisposable
    Example
    Get a Terrain Definition
      string path = @"d:\Data\Terrain\filegdb_Containing_A_Terrain.gdb";
      var fileConnection = new FileGeodatabaseConnectionPath(new Uri(path));
      //Note: Use QueuedTask.Run to run on the MCT
      using (Geodatabase dataStore = new Geodatabase(fileConnection))
        string dsName = "nameOfTerrain";
        using (var terrainDefinition = dataStore.GetDefinition<ArcGIS.Core.Data.Analyst3D.TerrainDefinition>(dsName))
          // get the feature class names that are used in the terrain
          var fcNames = terrainDefinition.GetFeatureClassNames();
    Retrieve dataset objects
      //Note: Needs QueuedTask to run
        using (var tin = tinLayer.GetTinDataset())
          using var tinDef = tin.GetDefinition();
          Envelope extent = tinDef.GetExtent();
          SpatialReference sr = tinDef.GetSpatialReference();
        using (terrain = terrainLayer.GetTerrain())
          using var terrainDef = terrain.GetDefinition();
          Envelope extent = terrainDef.GetExtent();
          SpatialReference sr = terrainDef.GetSpatialReference();
        using (lasDataset = lasDatasetLayer.GetLasDataset())
          using var lasDatasetDef = lasDataset.GetDefinition();
          Envelope extent = lasDatasetDef.GetExtent();
          SpatialReference sr = lasDatasetDef.GetSpatialReference();
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
    Requirements
    ArcGIS Pro version: 3.2 or higher.
