ArcGIS.Core.Data.Analyst3D Namespace / TinDataset Class / GetNodeCount Method
Example
    GetNodeCount Method
    Gets the total number of nodes in this TIN. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetNodeCount() As Integer
    public int GetNodeCount()
    Return Value
    The total number of nodes in this TIN.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    When looping through all the nodes, the loop starts at index = 1.
    Example
    Element Counts
      var nodeCount = tinDataset.GetNodeCount();
      var outsideNodeCount = tinDataset.GetOutsideNodeCount();
      var edgeCount = tinDataset.GetEdgeCount();
      var outsideEdgecount = tinDataset.GetOutsideEdgeCount();
      var triCount = tinDataset.GetTriangleCount();
      var outsideTriCount = tinDataset.GetOutsideTriangleCount();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
