Return Value
The number of outside edges in this TIN.
| Exception | Description |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
When looping through the edges, the loop starts at index = 1.
var nodeCount = tinDataset.GetNodeCount();
var outsideNodeCount = tinDataset.GetOutsideNodeCount();
var edgeCount = tinDataset.GetEdgeCount();
var outsideEdgecount = tinDataset.GetOutsideEdgeCount();
var triCount = tinDataset.GetTriangleCount();
var outsideTriCount = tinDataset.GetOutsideTriangleCount();
