ArcGIS.Core.Data.Analyst3D Namespace / TinDataset Class / SearchEdges Method
Filter by parameters. See TinEdgeFilter. If null, then all single edges that intersect the data extent will be retrieved.
Example
    SearchEdges Method (TinDataset)
    Retrieves the edges in the TIN that satisfy the criteria set in the filter. If no filter is set, all single edges that intersect the data extent will be retrieved. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function SearchEdges( _
       ByVal filter As TinEdgeFilter _
    ) As TinEdgeCursor
    public TinEdgeCursor SearchEdges(
       TinEdgeFilter filter
    Parameters
    filter
    Return Value
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    To ensure maximum robustness, callers should explicitly dispose of the returned TinEdgeCursor in either a using statement or a finally block.
    Example
    Search for TIN Edges
      // search all single edges that intersect the data extent
      using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinDataset.SearchEdges(null))
        while (edgeCursor.MoveNext())
          using (ArcGIS.Core.Data.Analyst3D.TinEdge edgeCurrent = edgeCursor.Current)
            // do something with the edge
      // search within an extent
      ArcGIS.Core.Data.Analyst3D.TinEdgeFilter edgeFilter = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
      edgeFilter.FilterEnvelope = envelope;
      using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinDataset.SearchEdges(edgeFilter))
      // search all "inside" edges
      edgeFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
      // search for hard edges
      edgeFilter.FilterByEdgeType = true;
      edgeFilter.EdgeType = ArcGIS.Core.Data.Analyst3D.TinEdgeType.HardEdge;
    Requirements
    ArcGIS Pro version: 3.2 or higher.
