ArcGIS.Core.Data.Analyst3D Namespace / TinDataset Class / UsesConstrainedDelaunay Method
Example
    UsesConstrainedDelaunay Method (TinDataset)
    Gets if the TIN is defined using the Constrained Delaunay triangulation technique. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function UsesConstrainedDelaunay() As Boolean
    public bool UsesConstrainedDelaunay()
    Return Value
    True if the TIN is defined using the Constrained Delaunay triangulation technique.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Tin Properties
      var isEmpty = tinDataset.GetIsEmpty();
      var hasHardEdges = tinDataset.HasHardEdges();
      var hasSoftEdges = tinDataset.HasSoftEdges();
      var isConstrainedDelaunay = tinDataset.UsesConstrainedDelaunay();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
