ArcGIS.Desktop.Mapping Namespace / LasPointClassBreaksRendererDefinition Class
Members Example
    Represents a class breaks renderer definition to draw points in a LAS dataset layer.
    Object Model
    LasPointClassBreaksRendererDefinition ClassCIMColorRamp ClassCIMSymbolReference Class
    Syntax
    Public Class LasPointClassBreaksRendererDefinition
       Inherits TinColorRampRendererDefinition
    public class LasPointClassBreaksRendererDefinition : TinColorRampRendererDefinition
    Remarks
    A LasPointClassBreaksRendererDefinition has a fixed CursorType of ArcGIS.Core.CIM.TerrainDrawCursorType.TerrainPointElevation and is only applicable to a LAS dataset layer.
    Once you define a class breaks renderer, you can call a surface layer's CanCreateRenderer, CreateRenderer, CanSetRenderer and SetRenderer methods to create and assign a renderer to a surface layer.
    Example
    LAS Points Classified Elevation Renderer
      var lasPointsClassBreaksRendererDef = new LasPointClassBreaksRendererDefinition();
      lasPointsClassBreaksRendererDef.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      lasPointsClassBreaksRendererDef.ModulateUsingIntensity = true;
      // increase the symbol size by a factor
      lasPointsClassBreaksRendererDef.SymbolScaleFactor = 1.0;
      // Note: Needs QueuedTask to run
        if (lasDatasetLayer.CanCreateRenderer(lasPointsClassBreaksRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassBreaksRendererDef);
          if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LayerDrawingDefinition
          ArcGIS.Desktop.Mapping.TinRendererDefinition
             ArcGIS.Desktop.Mapping.TinColorRampRendererDefinition
                ArcGIS.Desktop.Mapping.LasPointClassBreaksRendererDefinition
    Requirements
    ArcGIS Pro version: 3.2 or higher.
