Public MustInherit Class TinRendererDefinition Inherits LayerDrawingDefinition
public abstract class TinRendererDefinition : LayerDrawingDefinition
var tinCP_renderers = new TinLayerCreationParams(tinDataset)
Name = "My TIN layer",
IsVisible = true
// define the node renderer - use defaults
var node_rd = new TinNodeRendererDefinition();
// define the face/surface renderer
var face_rd = new TinFaceClassBreaksRendererDefinition();
face_rd.ClassificationMethod = ClassificationMethod.NaturalBreaks;
// accept default color ramp, breakCount
// set up the renderer dictionary
var rendererDict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>
{ SurfaceRendererTarget.Points, node_rd },
{ SurfaceRendererTarget.Surface, face_rd }
// assign the dictionary to the creation params
tinCP_renderers.RendererDefinitions = rendererDict;
// Note: Needs QueuedTask to run
// create the layer
var tinLayer_rd = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP_renderers, MapView.Active.Map);
var terrainCP_renderers = new TerrainLayerCreationParams(terrain);
terrainCP_renderers.Name = "My LAS Layer";
terrainCP_renderers.IsVisible = true;
// define the edge type renderer - use defaults
var edgeRD = new TinBreaklineRendererDefinition();
var faceRD = new TinFaceClassBreaksRendererDefinition();
faceRD.ClassificationMethod = ClassificationMethod.NaturalBreaks;
// define the dirty area renderer - use defaults
var dirtyAreaRD = new TerrainDirtyAreaRendererDefinition();
// add renderers to dictionary
var t_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
t_dict.Add(SurfaceRendererTarget.Edges, edgeRD);
t_dict.Add(SurfaceRendererTarget.Surface, faceRD);
t_dict.Add(SurfaceRendererTarget.DirtyArea, dirtyAreaRD);
// assign dictionary to creation params
terrainCP_renderers.RendererDefinitions = t_dict;
//Create the layer to the terrain
var terrainLayer_rd = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP_renderers, map);
var lasCP_renderers = new LasDatasetLayerCreationParams(lasDataset);
lasCP_renderers.Name = "My LAS Layer";
lasCP_renderers.IsVisible = false;
// create a point elevation renderer
var ptR = new LasStretchRendererDefinition();
// accept all defaults
// create a simple edge renderer
var edgeR = new TinEdgeRendererDefintion();
var l_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
l_dict.Add(SurfaceRendererTarget.Points, ptR);
l_dict.Add(SurfaceRendererTarget.Edges, edgeR);
lasCP_renderers.RendererDefinitions = l_dict;
//Create the layer to the LAS dataset
var lasDatasetLayer_rd = LayerFactory.Instance.CreateLayer<LasDatasetLayer>(lasCP_renderers, map);
System.Object
ArcGIS.Desktop.Mapping.LayerDrawingDefinition
ArcGIS.Desktop.Mapping.TinRendererDefinition
ArcGIS.Desktop.Mapping.LasStretchRendererDefinition
ArcGIS.Desktop.Mapping.TinColorRampRendererDefinition
ArcGIS.Desktop.Mapping.TinContourRendererDefinition
ArcGIS.Desktop.Mapping.TinFaceClassBreaksAspectRendererDefinition
ArcGIS.Desktop.Mapping.TinSimpleRendererDefinition
ArcGIS.Desktop.Mapping.TinUniqueValueRendererDefinition
