ArcGIS.Desktop.Mapping Namespace / LasStretchRendererDefinition Class
Members Example
    Represents a LAS stretch renderer definition.
    Object Model
    LasStretchRendererDefinition ClassCIMColorRamp Class
    Syntax
    Public Class LasStretchRendererDefinition
       Inherits TinRendererDefinition
    public class LasStretchRendererDefinition : TinRendererDefinition
    Remarks
    Once you define a LAS stretch renderer, you can call a surface layer's CanCreateRenderer, CreateRenderer, CanSetRenderer and SetRenderer methods to create and assign a renderer to a surface layer.
    Example
    Create a LasDatasetLayer with renderers
      var lasCP_renderers = new LasDatasetLayerCreationParams(lasDataset);
      lasCP_renderers.Name = "My LAS Layer";
      lasCP_renderers.IsVisible = false;
      // create a point elevation renderer
      var ptR = new LasStretchRendererDefinition();
      // accept all defaults
      // create a simple edge renderer
      var edgeR = new TinEdgeRendererDefintion();
      // add renderers to dictionary
      var l_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
      l_dict.Add(SurfaceRendererTarget.Points, ptR);
      l_dict.Add(SurfaceRendererTarget.Edges, edgeR);
      // assign dictionary to creation params
      lasCP_renderers.RendererDefinitions = l_dict;
      // Note: Needs QueuedTask to run
        //Create the layer to the LAS dataset
        var lasDatasetLayer_rd = LayerFactory.Instance.CreateLayer<LasDatasetLayer>(lasCP_renderers, map);
    LAS Points Elevation Stretch Renderer
      var elevLasStretchRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
      // accept the defaults for color ramp, etc
      if (lasDatasetLayer.CanCreateRenderer(elevLasStretchRendererDef))
        CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchRendererDef);
        if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
          lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
      // OR use a stretch renderer with stretchType standard Deviations
      var elevLasStretchStdDevRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
      elevLasStretchStdDevRendererDef.StretchType = LASStretchType.StandardDeviations;
      elevLasStretchStdDevRendererDef.NumberOfStandardDeviations = 2;
        if (lasDatasetLayer.CanCreateRenderer(elevLasStretchStdDevRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchStdDevRendererDef);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LayerDrawingDefinition
          ArcGIS.Desktop.Mapping.TinRendererDefinition
             ArcGIS.Desktop.Mapping.LasStretchRendererDefinition
    Requirements
    ArcGIS Pro version: 3.2 or higher.
