ArcGIS.Desktop.Mapping Namespace / TinEdgeRendererDefintion Class
Members Example
    Represents a simple renderer definition to draw all edges in a surface layer with a common symbol.
    Object Model
    TinEdgeRendererDefintion ClassCIMSymbolReference Class
    Syntax
    Public Class TinEdgeRendererDefintion
       Inherits TinSimpleRendererDefinition
    public class TinEdgeRendererDefintion : TinSimpleRendererDefinition
    Remarks
    The symbol used to define the TinSimpleRendererDefinition.SymbolTemplate should be a ArcGIS.Core.CIM.CIMLineSymbol.
    Once you define a simple renderer, you can call a surface layer's CanCreateRenderer, CreateRenderer, CanSetRenderer and SetRenderer methods to create and assign a renderer to a surface layer.
    Example
    Create a LasDatasetLayer with renderers
      var lasCP_renderers = new LasDatasetLayerCreationParams(lasDataset);
      lasCP_renderers.Name = "My LAS Layer";
      lasCP_renderers.IsVisible = false;
      // create a point elevation renderer
      var ptR = new LasStretchRendererDefinition();
      // accept all defaults
      // create a simple edge renderer
      var edgeR = new TinEdgeRendererDefintion();
      // add renderers to dictionary
      var l_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
      l_dict.Add(SurfaceRendererTarget.Points, ptR);
      l_dict.Add(SurfaceRendererTarget.Edges, edgeR);
      // assign dictionary to creation params
      lasCP_renderers.RendererDefinitions = l_dict;
      // Note: Needs QueuedTask to run
        //Create the layer to the LAS dataset
        var lasDatasetLayer_rd = LayerFactory.Instance.CreateLayer<LasDatasetLayer>(lasCP_renderers, map);
    Simple Edge Renderer
      // applies to TIN or LAS dataset layers only
      var edgeRendererDef = new TinEdgeRendererDefintion();
      edgeRendererDef.Description = "Edges";
      edgeRendererDef.Label = "Edges";
      edgeRendererDef.SymbolTemplate = lineSymbol.MakeSymbolReference();
        if (surfaceLayer.CanCreateRenderer(edgeRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(edgeRendererDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LayerDrawingDefinition
          ArcGIS.Desktop.Mapping.TinRendererDefinition
             ArcGIS.Desktop.Mapping.TinSimpleRendererDefinition
                ArcGIS.Desktop.Mapping.TinEdgeRendererDefintion
    Requirements
    ArcGIS Pro version: 3.2 or higher.
