ArcGIS.Desktop.Mapping Namespace / TinFaceClassBreaksRendererDefinition Class
Members Example
    Represents a class breaks renderer definition to draw faces in a surface layer.
    Object Model
    TinFaceClassBreaksRendererDefinition ClassCIMColorRamp ClassCIMSymbolReference Class
    Syntax
    Public Class TinFaceClassBreaksRendererDefinition
       Inherits TinColorRampRendererDefinition
    public class TinFaceClassBreaksRendererDefinition : TinColorRampRendererDefinition
    Remarks
    Once you define a class breaks renderer, you can call a surface layer's CanCreateRenderer, CreateRenderer, CanSetRenderer and SetRenderer methods to create and assign a renderer to a surface layer.
    Example
    Create a TinLayer with renderers
      var tinCP_renderers = new TinLayerCreationParams(tinDataset)
        Name = "My TIN layer",
        IsVisible = true
      // define the node renderer - use defaults
      var node_rd = new TinNodeRendererDefinition();
      // define the face/surface renderer
      var face_rd = new TinFaceClassBreaksRendererDefinition();
      face_rd.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      // accept default color ramp, breakCount
      // set up the renderer dictionary
      var rendererDict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>
      { SurfaceRendererTarget.Points, node_rd },
      { SurfaceRendererTarget.Surface, face_rd }
      // assign the dictionary to the creation params
      tinCP_renderers.RendererDefinitions = rendererDict;
      // Note: Needs QueuedTask to run
        // create the layer
        var tinLayer_rd = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP_renderers, MapView.Active.Map);
    Create a TerrainLayer with renderers
      var terrainCP_renderers = new TerrainLayerCreationParams(terrain);
      terrainCP_renderers.Name = "My LAS Layer";
      terrainCP_renderers.IsVisible = true;
      // define the edge type renderer - use defaults
      var edgeRD = new TinBreaklineRendererDefinition();
      var faceRD = new TinFaceClassBreaksRendererDefinition();
      faceRD.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      // define the dirty area renderer - use defaults
      var dirtyAreaRD = new TerrainDirtyAreaRendererDefinition();
      // add renderers to dictionary
      var t_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
      t_dict.Add(SurfaceRendererTarget.Edges, edgeRD);
      t_dict.Add(SurfaceRendererTarget.Surface, faceRD);
      t_dict.Add(SurfaceRendererTarget.DirtyArea, dirtyAreaRD);
      // assign dictionary to creation params
      terrainCP_renderers.RendererDefinitions = t_dict;
        //Create the layer to the terrain
        var terrainLayer_rd = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP_renderers, map);
    Slope Face Renderer - Equal Interval
      var slopeFaceClassBreaksEqual = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
      // accept default breakCount, symbolTemplate, color ramp
        if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksEqual))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksEqual);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Surface))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Surface);
    Slope Face Renderer - Quantile
      var slopeFaceClassBreaksQuantile = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
      slopeFaceClassBreaksQuantile.ClassificationMethod = ClassificationMethod.Quantile;
        if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksQuantile))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksQuantile);
    Elevation Face Renderer - Equal Interval
      var elevFaceClassBreaksEqual = new TinFaceClassBreaksRendererDefinition();
        if (surfaceLayer.CanCreateRenderer(elevFaceClassBreaksEqual))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(elevFaceClassBreaksEqual);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LayerDrawingDefinition
          ArcGIS.Desktop.Mapping.TinRendererDefinition
             ArcGIS.Desktop.Mapping.TinColorRampRendererDefinition
                ArcGIS.Desktop.Mapping.TinFaceClassBreaksRendererDefinition
    Requirements
    ArcGIS Pro version: 3.2 or higher.
