ArcGIS.Desktop.Mapping Namespace / TinFaceRendererDefinition Class
Members Example
    Represents a simple renderer definition to draw all faces in a surface layer with a common symbol.
    Object Model
    TinFaceRendererDefinition ClassCIMSymbolReference Class
    Syntax
    Public Class TinFaceRendererDefinition
       Inherits TinSimpleRendererDefinition
    public class TinFaceRendererDefinition : TinSimpleRendererDefinition
    Remarks
    The symbol used to define the TinSimpleRendererDefinition.SymbolTemplate should be a ArcGIS.Core.CIM.CIMPolygonSymbol.
    Once you define a simple renderer, you can call a surface layer's CanCreateRenderer, CreateRenderer, CanSetRenderer and SetRenderer methods to create and assign a renderer to a surface layer.
    Example
    Simple Face Renderer
      var simpleFaceRendererDef = new TinFaceRendererDefinition();
      simpleFaceRendererDef.SymbolTemplate = polySymbol.MakeSymbolReference();
      // Note: Needs QueuedTask to run
        if (surfaceLayer.CanCreateRenderer(simpleFaceRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(simpleFaceRendererDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Surface))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Surface);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LayerDrawingDefinition
          ArcGIS.Desktop.Mapping.TinRendererDefinition
             ArcGIS.Desktop.Mapping.TinSimpleRendererDefinition
                ArcGIS.Desktop.Mapping.TinFaceRendererDefinition
    Requirements
    ArcGIS Pro version: 3.2 or higher.
