ArcGIS.Core.CIM Namespace / CentralityRelationshipInterpretation Enumeration
Example Example
    Specifies the way relationships are interpreted for centrality computations.
    Syntax
    Public Enum CentralityRelationshipInterpretation
       Inherits System.Enum
       Implements System.IComparable, System.IConvertible, System.IFormattable, System.ISpanFormattable
    public enum CentralityRelationshipInterpretation : System.Enum, System.IComparable, System.IConvertible, System.IFormattable, System.ISpanFormattable
    Members
    MemberDescription
    Directed Relationships are considered to be directed.
    Reversed Relationships are considered to be directed and their direction is reversed.
    Undirected Relationships are considered to be undirected.
    Remarks
    CentralityMeasure.Coreness is only compatible with Undirected.
    Example
    Configure Centrality
      //using ArcGIS.Core.Data.Knowledge.Extensions;
      await QueuedTask.Run(() =>
        //using(var kg = ....) {
        //configure centrality with custom settings
        var kg_config = new CIMKnowledgeGraphCentralityConfiguration()
          RelationshipsInterpretation = CentralityRelationshipInterpretation.Directed,
          MultiedgeFactor = 1.0,//cumulative importance
          Normalization = CentralityScoresNormalization.None,
          DefaultRelationshipCost = 1.0,
          DefaultRelationshipImportance = 1.0,
          RelationshipCostProperty = string.Empty,
          RelationshipImportanceProperty = string.Empty
        //include all entities from the kg in the subgraph
        //(no filters)
        var kg_subgraph = new CIMKnowledgeGraphSubGraph();
        //include the relevant centrality measures
        CentralityMeasure[] measures = [
          CentralityMeasure.Degree,
    CentralityMeasure.InDegree,
    CentralityMeasure.OutDegree,
    CentralityMeasure.Betweenness,
    CentralityMeasure.Closeness,
    CentralityMeasure.Harmonic,
    CentralityMeasure.Eigenvector,
    CentralityMeasure.PageRank
        //Note: CentralityMeasure.Coreness cannot be calculated
        //with directed relationships, so it is not included here.
        //Specfying Coreness (with directed or reveresed relationships) will
        //throw an exception
        //compute centrality
        var kg_centrality_results = kg.ComputeCentrality(
                                          kg_config, kg_subgraph, measures);
        //TODO process results
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.CentralityRelationshipInterpretation
    Requirements
    ArcGIS Pro version: 3.3 or higher.
