ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphLayerIDSet Class / FromKnowledgeGraph Method / FromKnowledgeGraph(Uri,KnowledgeGraphFilterType) Method
A Uri link to a knowledge graph service or file-based knowledge graph
The type of named type objects to include in the filter set.
Example
    Creates a KnowledgeGraphLayerIDSet with a particular filter type. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    knowledgeGraphPathOrServiceUri
    filterType
    Return Value
    Exceptions
    ExceptionDescription
    The knowledgeGraphPathOrServiceUri is null.
    Example
    Create a Link Chart Containing All Records for a KG
      await QueuedTask.Run(() =>
        //Create the link chart and show it
        //build the IDSet using KnowledgeGraphFilterType.AllNamedObjects
        var idSet = KnowledgeGraphLayerIDSet.FromKnowledgeGraph(
          kg, KnowledgeGraphFilterType.AllNamedObjects);
        var linkChart = MapFactory.Instance.CreateLinkChart(
                          "KG Link Chart", kg, idSet);
        FrameworkApplication.Panes.CreateMapPaneAsync(linkChart);
    Create a link chart with all the entities of the Knowledge Graph
        using (var kg_for_lc = new KnowledgeGraph(
          new KnowledgeGraphConnectionProperties(new Uri(url))))
            kg_for_lc, KnowledgeGraphFilterType.AllEntities);
          var newLinkChart = MapFactory.Instance.CreateLinkChart(
            "All_Entities link chart", kg_for_lc, idSet);
    Create a link chart based on a template link chart
      // note that the template link chart MUST use the same KG server
        // find the existing link chart by name
        var projectItem = Project.Current.GetItems<MapProjectItem>()
        .FirstOrDefault(pi => pi.Name == "Acme Link Chart");
        var linkChartMap = projectItem?.GetMap();
        if (linkChartMap == null)
          return;
        //Create a connection properties
        var kg_props2 =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        try
          //Open a connection
          using (var kg_for_lc = new KnowledgeGraph(kg_props2))
            //Add all entities to the link chart
            //Create the new link chart and show it
                              "KG from Template", kg_for_lc, idSet, linkChartMap.URI);
            FrameworkApplication.Panes.CreateMapPaneAsync(newLinkChart);
        catch (Exception ex)
          System.Diagnostics.Debug.WriteLine(ex.ToString());
    Requirements
    ArcGIS Pro version: 3.3 or higher.
