ArcGIS.Desktop.Mapping Namespace / AIXFormat Class
    AIXFormat Class Properties
    For a list of all members of this type, see AIXFormat members.
    Public Properties
     NameDescription
    Public Property Get or sets if the layout is clipped to the smallest bounding box that encompasses all layout elements. (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Public Property Gets or sets a Boolean that controls compression of vector and text portions of the output file. Image compression is defined separately.
    Public Property Gets or sets a Boolean that controls the conversion of character marker symbols to polygon.
    Public Property Gets or sets a Boolean that controls the embedding of fonts in the export file.
    Public Property Get or sets if the selection symbology should be shown for all the layers. (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Public Property Gets or sets if a color profile is embedded.
    Public Property Gets or sets if the output will have white background.
    Public Property Gets or sets the caption. (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Public Property Gets or sets the number of pixels that represents the height of the output file. (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Public Property Gets or sets the compression scheme used to compress image or raster data in the output file.
    Public Property This value (0–100) controls the amount of compression applied to the output image. With a JPEG image, quality is adversely affected the more compression is applied. A higher quality (highest = 100) setting will produce sharper images and larger file sizes. A lower quality setting will produce more image artifacts and smaller files.
    Public Property Gets or sets the output image quality - the draw resolution of map layers that draw as rasters.
    Public Property Gets or sets if the output will have non-visible map layers.
    Public Property Gets or sets the path and file name for the output export file. (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Public Property Gets or sets the resolution of the export file in dots per inch (DPI). (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Public Property Gets or sets the number of pixels that represents the width of the output file. (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Top
