ArcGIS.Core.Data Namespace / Table Class / ValidateContingencies Method
RowBuffer to determine valid and invalid contingencies.
Example
    Validate contingency constraints to distinguish between valid and invalid contingencies.
    Syntax
    Public Function ValidateContingencies( _
       ByVal rowBuffer As RowBuffer _
    ) As ContingencyValidationResult
    public ContingencyValidationResult ValidateContingencies(
       RowBuffer rowBuffer
    Parameters
    rowBuffer
    Return Value
    The contingency validation result, ContingencyValidationResult.
    Exceptions
    ExceptionDescription
    rowBuffer is null.
    A geodatabase-related exception has occurred.
    Example
    Validate contingent attribute values
      // Must be called within QueuedTask.Run
      void ValidateContingentValues(FeatureClass parcels, string zoningFieldName = "Zone", string taxCodeFieldName = "TaxCode")
        using (RowBuffer rowBuffer = parcels.CreateRowBuffer())
          // Insert values in a row buffer
          rowBuffer[zoningFieldName] = "Business";
          rowBuffer[taxCodeFieldName] = "TaxB";
          // Validate contingency values of the parcels' row
          ContingencyValidationResult contingencyValidationResult = parcels.ValidateContingencies(rowBuffer);
          // Valid contingencies
          IReadOnlyList<Contingency> matchedContingencies = contingencyValidationResult.Matches;
          if (matchedContingencies.Count > 0)
            // Create a row with valid contingency values
            parcels.CreateRow(rowBuffer);
          // Invalid contingencies
          IReadOnlyList<ContingencyViolation> violatedContingencies = contingencyValidationResult.Violations;
          foreach (ContingencyViolation contingencyViolation in violatedContingencies)
            ContingencyViolationType violationType = contingencyViolation.Type;
            Contingency violatedContingency = contingencyViolation.Contingency;
    Requirements
    ArcGIS Pro version: 3.4 or higher.
