ArcGIS.Desktop.KnowledgeGraph Namespace / KnowledgeGraphInvestigationView Class / GetSelectedRecords Method
Example
    Gets the selected records. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetSelectedRecords() As KnowledgeGraphLayerIDSet
    public KnowledgeGraphLayerIDSet GetSelectedRecords()
    Return Value
    A ArcGIS.Desktop.Mapping.KnowledgeGraphLayerIDSet representing the selected records.
    Exceptions
    ExceptionDescription
    Example
    Get Selected records and open in a new link chart
      // get the active investigation view
      var iv = KnowledgeGraphInvestigationView.Active;
      await QueuedTask.Run(() =>
        // get the investigation
        var inv = iv.Investigation;
        // get the set of selected records
        var idSet = iv.GetSelectedRecords();
        // view these records in a link chart
        var map = MapFactory.Instance.CreateLinkChart("myLinkChart", new Uri(inv.ServiceUri), idSet);
        ProApp.Panes.CreateMapPaneAsync(map);
    Requirements
    ArcGIS Pro version: 3.5 or higher.
