ArcGIS.Desktop.Core Namespace / EditingProjectExtender Class / SetSingleEditWorkspaceAsync Method / SetSingleEditWorkspaceAsync(Project,Datastore) Method
The datastore to edit.
    Start a single edit workspace session using the specified datastore.
    Syntax
    Public Overloads Shared Function SetSingleEditWorkspaceAsync( _
       ByVal project As Project, _
       ByVal datastore As Datastore _
    ) As Task(Of Boolean)
    public static Task<bool> SetSingleEditWorkspaceAsync(
       Project project,
       Datastore datastore
    Parameters
    project
    datastore
    Return Value
    A task representing a value indicating if the edit session was started.
    Exceptions
    ExceptionDescription
    The project is not configured for editing single workspaces.
    A workspace is already being edited and has pending edits. Save or discard these edits first.
    A workspace is already being edited. Stop editing this workspace first.
    Remarks
    This method can only be used when EditingOptions.EnableEditingFromEditTab and EditingOptions.IsSingleWorkspaceEditSession are true. If the settings are not set then an System.InvalidOperationException will be thrown.
    Use this method for editing a file, memory, mobile or other non enterprise geodatabase. Use SetSingleEditWorkspaceAsync(Project,DatastoreConfiguration) for editing an enterprise geodatabase.
    Requirements
    ArcGIS Pro version: 3.6 or higher.
