ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphMappingExtensions Class / SetLinkChartContent Method
The link chart to have its content updated.
The set of named object types and records.
The combination method.
Example
    Applies a set of named object types and their records to the link chart map using the specified IDSetCombinationMethod. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Sub SetLinkChartContent( _
       ByVal linkChart As Map, _
       ByVal idSet As KnowledgeGraphLayerIDSet, _
       ByVal combinationMethod As IDSetCombinationMethod _
    Parameters
    linkChart
    idSet
    combinationMethod
    Exceptions
    ExceptionDescription
    Map is not a link chart or does not contain a Knowledge Graph layer.
    Cannot clear link chart content.
    idSet contains invalid Name Object types..
    Remarks
    You should use CanSetLinkChartContent(Map,KnowledgeGraphLayerIDSet,IDSetCombinationMethod) prior to this method.
    Add an entry to the idSet for each Named Object type along with a list of their relevant record ids. if using a combinationMethod of IDSetCombinationMethod.Add or IDSetCombinationMethod.New you can specify a null or empty list for a given entry to add all the records for that particular type at the time of this operation.
    Note: Named Object names in an ID set entry are case-sensitive.
    If there are Named Object type names specified in the ID set that do not match a Named Object type name in the KnowledgeGraph then a KnowledgeGraphLayerException will be thrown. The exception will contain the list of invalid Named Object types.
    Example
    Set only the Selected Features as the Link Chart content
      if (!MapView.Active?.Map?.IsLinkChart == true)
        return;
      await QueuedTask.Run(() =>
        var map = MapView.Active.Map;
        var sel_set = map.GetSelection();
        if (sel_set.Count > 0)
          var kg_layer_id_set = KnowledgeGraphLayerIDSet.FromSelectionSet(sel_set);
          //IDSetCombinationMethod can be New, Add, or Subtract
          if (map.CanSetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.New))
            map.SetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.New);
    Append a set of records to a link chart
        return;
      //Assume we have a set of features in an entity type 'Species' and an entity
      //type 'Observation' that we want to append to an existing link chart...
      //Create a dictionary containing the entity uids to be added...
      var dict = new Dictionary<string, List<object>>();
      dict["Species"] = new List<object>();
      dict["Observation"] = new List<object>();
      dict["Species"].Add("{4478D960-A4D6-4930-A151-51A2C6140509}");
      dict["Species"].Add("{97E011A0-C140-4EA9-84E6-19413F6FCEE3}");
      dict["Observation"].Add("{18E1DB21-9F61-4CBE-A488-71AC8B24B605}");
      dict["Observation"].Add("{E378F1B1-FF5E-4EDD-808A-1C395A4857AD}");
        //Get the knowledge graph layer from the link chart
        var kg_layer = MapView.Active?.Map?.GetLayersAsFlattenedList()?
                                  .OfType<ArcGIS.Desktop.Mapping.KnowledgeGraphLayer>()?
                                  .First();
        //arbitrarily get the first feature layer that is a child of the kg layer
        var fl = kg_layer?.GetLayersAsFlattenedList()?
                    .OfType<FeatureLayer>()?.First();
        //Get the kg from the kg layer
        using (var kg = kg_layer.GetDatastore())
          //Create a kg layer id set
          var id_set = KnowledgeGraphIDSet.FromDictionary(kg, dict);
          var kg_layer_id_set = KnowledgeGraphLayerIDSet.FromKnowledgeGraphIDSet(id_set);
          //set the content of the link chart using the id set and the Add combination method
          if (map.CanSetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.Add))
            map.SetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.Add);
            //Set the newly added records selected...
            map.SetSelection(SelectionSet.FromKnowledgeGraphLayerIDSet(map, kg_layer_id_set));
    Remove the selected features from the link chart's content
        return;
          if (map.CanSetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.Subtract))
            map.SetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.Subtract);
    Requirements
    ArcGIS Pro version: 3.7 or higher.
