ArcGIS.Core.Data.DDL Namespace / SchemaBuilder Class / Delete Method
Indicates the object to be deleted.
Example
    Delete Method (SchemaBuilder)
    Enqueue the delete operation on the object with the name referred to by the Description. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub Delete( _
       ByVal description As Description _
    public void Delete(
       Description description
    Parameters
    description
    Exceptions
    ExceptionDescription
    description is null.
    The FID index cannot be deleted
    Remarks
    When deleting domains, a CodedValueDomainDescription must be used to delete a ArcGIS.Core.Data.CodedValueDomain and a RangeDomainDescription must be used to delete a ArcGIS.Core.Data.RangeDomain. When deleting an object from a geodatabase, the geodatabase must be set as the datasource. When deleting a named object type from a knowledge graph, the knowledge graph must be set as the datasource. If the wrong datasource is detected for the given input description then a System.InvalidOperationException will be thrown.
    An attribute index on object id cannot be deleted. Attempting to delete the attribute index on the global id field of a knowledge graph dataset will be ignored.
    Example
    Deleting a Table
      // Must be called within QueuedTask.Run
      void DeleteTableSnippet(Geodatabase geodatabase, Table table)
        // Create a TableDescription object
        TableDescription tableDescription = new TableDescription(table.GetDefinition());
        // Create a SchemaBuilder object
        SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
        // Add the deletion of the table to our list of DDL tasks
        schemaBuilder.Delete(tableDescription);
        // Execute the DDL
        bool success = schemaBuilder.Build();
    Deleting a Feature Class
      void DeleteFeatureClassSnippet(Geodatabase geodatabase, FeatureClass featureClass)
        // Create a FeatureClassDescription object
        FeatureClassDescription featureClassDescription = new FeatureClassDescription(featureClass.GetDefinition());
        // Add the deletion fo the feature class to our list of DDL tasks
        schemaBuilder.Delete(featureClassDescription);
        // Execute the DDL
    Removing attribute index
      void RemoveAttributeIndex(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition, string attributeIndexName)
        // Find a index to be removed
        ArcGIS.Core.Data.Index indexToRemove = featureClassDefinition.GetIndexes().First(f => f.GetName().Equals(attributeIndexName));
        // Index description of the index to be removed
        AttributeIndexDescription indexDescriptionToRemove = new AttributeIndexDescription(indexToRemove, new TableDescription(featureClassDefinition));
        // Enqueue the DDL operation to remove index
        schemaBuilder.Delete(indexDescriptionToRemove);
        // Execute the delete index operation
        bool isDeleteIndexSuccess = schemaBuilder.Build();
    Removing spatial index
      void RemoveSpatialIndex(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition)
        // Create a spatial description
        SpatialIndexDescription spatialIndexDescription = new SpatialIndexDescription(new FeatureClassDescription(featureClassDefinition));
        schemaBuilder.Delete(spatialIndexDescription);
    Delete domain
      void DeleteDomain(Geodatabase geodatabase, string domainNameToBeDeleted = "PipeMaterial")
        CodedValueDomain codedValueDomain = geodatabase.GetDomains().First(f => f.GetName().Equals(domainNameToBeDeleted)) as CodedValueDomain;
        CodedValueDomainDescription codedValueDomainDescription = new CodedValueDomainDescription(codedValueDomain);
        // Deleting a coded value domain
        schemaBuilder.Delete(codedValueDomainDescription);
    Deleting a relationship class
      void DeleteRelationshipClass(SchemaBuilder schemaBuilder, RelationshipClassDefinition relationshipClassDefinition)
        schemaBuilder.Delete(new RelationshipClassDescription(relationshipClassDefinition));
    Deleting a FeatureDataset
      void DeleteFeatureDatasetSnippet(Geodatabase geodatabase)
        // Deleting a FeatureDataset named as 'Parcel_Information'
        FeatureDatasetDefinition featureDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>("Parcel_Information");
        FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetDefinition);
        // Delete an existing feature dataset named as 'Parcel_Information'
        schemaBuilder.Delete(featureDatasetDescription);
    Delete Entity and Relationship Types with SchemaBuilder
      await QueuedTask.Run(() =>
        using (var kg = GetKnowledgeGraph(url))
          var entity_name = "PhoneCall";
          var relate_name = "WhoCalledWho";
          var entityDesc = new KnowledgeGraphEntityTypeDescription(entity_name);
          var relateDesc = new KnowledgeGraphRelationshipTypeDescription(relate_name);
          //Run the schema builder
          try
            SchemaBuilder sb = new(kg);
            sb.Delete(entityDesc);
            sb.Delete(relateDesc);
            //Use the KnowledgeGraph extension method 'ApplySchemaEdits(...)'
            //to refresh the Pro UI
            if (!kg.ApplySchemaEdits(sb))
              var err_msg = string.Join(",", sb.ErrorMessages.ToArray());
              System.Diagnostics.Debug.WriteLine($"Entity/Relate Delete error: {err_msg}");
          catch (Exception ex)
            System.Diagnostics.Debug.WriteLine(ex.ToString());
    Delete Attribute Indexes on KG Schemas with SchemaBuilder
          //indexes are managed on the GDB objects...
          var entity_table_def = kg.GetDefinition<TableDefinition>(entity_name);
          var entity_table_desc = new TableDescription(entity_table_def);
          var indexes = entity_table_def.GetIndexes();
          foreach (var idx in indexes)
            System.Diagnostics.Debug.WriteLine($"Index {idx.GetName()}");
          var idx1 = indexes.FirstOrDefault(
            idx => idx.GetName().ToLower() == "Index1".ToLower());
          var idx2 = indexes.FirstOrDefault(
            idx => idx.GetName().ToLower() == "Index2".ToLower());
          if (idx1 == null && idx2 == null)
            return;
          try
            if (idx1 != null)
              var idx_attr = new AttributeIndexDescription(idx1, entity_table_desc);
              sb.Delete(idx_attr);
            if (idx2 != null)
              var idx_attr = new AttributeIndexDescription(idx2, entity_table_desc);
              System.Diagnostics.Debug.WriteLine($"Delete index error: {err_msg}");
    Delete Domain on KG Schemas with SchemaBuilder
          //Get all the domains in the KG
          var domains = kg.GetDomains();
          var sb = new SchemaBuilder(kg);
          foreach (var domain in domains)
            //skip the special provenance domain
            var name = domain.GetName();
            if (string.Compare(name, "esri__provenanceSourceType", true) == 0)
              continue;//skip this one
            //Delete all other domains
            if (domain is ArcGIS.Core.Data.RangeDomain rd)
              sb.Delete(new RangeDomainDescription(rd));
            else if (domain is ArcGIS.Core.Data.CodedValueDomain cvd)
              sb.Delete(new CodedValueDomainDescription(cvd));
          try
            //note: will throw an InvalidOperationException if there are no operations
            //to run. Will also delete associated fields dependent on deleted domain(s)
              System.Diagnostics.Debug.WriteLine($"Delete domains error: {err_msg}");
    KnowledgeGraph GetKnowledgeGraph(string url)
      var kg_props =
        new KnowledgeGraphConnectionProperties(new Uri(url));
      return new KnowledgeGraph(kg_props);
    Requirements
