Public ReadOnly Property ErrorMessages As IReadOnlyList(Of String)
public IReadOnlyList<string> ErrorMessages {get;}
// Must be called within QueuedTask.Run
void CreateTableSnippet(Geodatabase geodatabase, CodedValueDomain inspectionResultsDomain)
// Create a PoleInspection table with the following fields
// GlobalID
// ObjectID
// InspectionDate (date)
// InspectionResults (pre-existing InspectionResults coded value domain)
// InspectionNotes (string)
// This helper routine creates a FieldDescription for a GlobalID field with default values
FieldDescription globalIDFieldDescription = FieldDescription.CreateGlobalIDField();
// This helper routine creates a FieldDescription for an ObjectID field with default values
FieldDescription objectIDFieldDescription = FieldDescription.CreateObjectIDField();
// Create a FieldDescription for the InspectionDate field
FieldDescription inspectionDateFieldDescription = new FieldDescription("InspectionDate", FieldType.Date)
AliasName = "Inspection Date"
// This helper routine creates a FieldDescription for a Domain field (from a pre-existing domain)
FieldDescription inspectionResultsFieldDescription = FieldDescription.CreateDomainField("InspectionResults",
new CodedValueDomainDescription(inspectionResultsDomain));
inspectionResultsFieldDescription.AliasName = "Inspection Results";
// This helper routine creates a FieldDescription for a string field
FieldDescription inspectionNotesFieldDescription =
FieldDescription.CreateStringField("InspectionNotes", 512);
inspectionNotesFieldDescription.AliasName = "Inspection Notes";
// Assemble a list of all of our field descriptions
List<FieldDescription> fieldDescriptions = new List<FieldDescription>()
globalIDFieldDescription, objectIDFieldDescription, inspectionDateFieldDescription,
inspectionResultsFieldDescription, inspectionNotesFieldDescription
// Create a TableDescription object to describe the table to create
TableDescription tableDescription = new TableDescription("PoleInspection", fieldDescriptions);
// Create a SchemaBuilder object
SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
// Add the creation of PoleInspection to our list of DDL tasks
schemaBuilder.Create(tableDescription);
// Execute the DDL
bool success = schemaBuilder.Build();
// Inspect error messages
if (!success)
IReadOnlyList<string> errorMessages = schemaBuilder.ErrorMessages;
//etc.
await QueuedTask.Run(() =>
using (var kg = GetKnowledgeGraph(url))
var entity_name = "PhoneCall";
var relate_name = "WhoCalledWho";
//Entity Fields
var descs1 =
new List<KnowledgeGraphPropertyDescription>();
descs1.Add(
new KnowledgeGraphPropertyDescription("PhoneOwner", FieldType.String));
descs1.Add(
new KnowledgeGraphPropertyDescription("PhoneNumber", FieldType.String));
descs1.Add(
new KnowledgeGraphPropertyDescription("LocationID", FieldType.BigInteger));
descs1.Add(
new KnowledgeGraphPropertyDescription("DateAndTime", FieldType.Date));
//Relate Fields
var descs2 =
descs2.Add(
new KnowledgeGraphPropertyDescription("Foo", FieldType.String));
descs2.Add(
new KnowledgeGraphPropertyDescription("Bar", FieldType.String));
var includeShape = true;//change to false to omit the shape column
var hasZ = false;
var hasM = false;
KnowledgeGraphEntityTypeDescription entityDesc = null;
KnowledgeGraphRelationshipTypeDescription relateDesc = null;
if (includeShape)
var sr = kg.GetSpatialReference();
var shp_desc = new ShapeDescription(GeometryType.Point, sr)
HasM = hasM,
HasZ = hasZ
entityDesc = new KnowledgeGraphEntityTypeDescription(
entity_name, descs1, shp_desc);
relateDesc = new KnowledgeGraphRelationshipTypeDescription(
relate_name, descs2, shp_desc);
else
entity_name, descs1);
relate_name, descs2);
//Run the schema builder
try
SchemaBuilder sb = new(kg);
sb.Create(entityDesc);
sb.Create(relateDesc);
//Use the KnowledgeGraph extension method 'ApplySchemaEdits(...)'
//to refresh the Pro UI
if (!kg.ApplySchemaEdits(sb))
var err_msg = string.Join(",", sb.ErrorMessages.ToArray());
System.Diagnostics.Debug.WriteLine($"Entity/Relate Create error: {err_msg}");
catch (Exception ex)
System.Diagnostics.Debug.WriteLine(ex.ToString());
