ArcGIS.Core.Data.DDL Namespace / SchemaBuilder Class / CreateGeodatabase Method / CreateGeodatabase(MobileGeodatabaseConnectionPath) Method
Represents the physical path to create the mobile ArcGIS.Core.Data.Geodatabase.
Example
    Creates a new mobile ArcGIS.Core.Data.Geodatabase at the specified path
    Syntax
    Parameters
    mobileGeodatabaseConnectionPath
    Return Value
    The newly created mobile ArcGIS.Core.Data.Geodatabase
    Exceptions
    ExceptionDescription
    The path contains an invalid character or the geodatabase name is invalid.
    -or-
    The length of the local path is greater than 215 characters.
    mobileGeodatabaseConnectionPath is null.
    The name of the file ArcGIS.Core.Data.Geodatabase contains a colon.
    The file ArcGIS.Core.Data.Geodatabase already exists.
    A geodatabase-related exception has occurred.
    Example
    Creating a Mobile Geodatabase
      await QueuedTask.Run(() =>
        // Create a MobileGeodatabaseConnectionPath with the name of the mobile geodatabase you wish to create
        MobileGeodatabaseConnectionPath mobileGeodatabaseConnectionPath =
          new MobileGeodatabaseConnectionPath(new Uri(@"C:\Path-To-Mobile-Geodatabase\YourName.geodatabase"));
        // Create and use the mobile geodatabase
        using (Geodatabase geodatabase = SchemaBuilder.CreateGeodatabase(mobileGeodatabaseConnectionPath))
          // Create additional schema here
    Requirements
