ArcGIS.Core.Data.DDL Namespace / SchemaBuilder Class / DeleteGeodatabase Method / DeleteGeodatabase(MobileGeodatabaseConnectionPath) Method
Represents the physical path of the mobile ArcGIS.Core.Data.Geodatabase
Example
    Deletes the mobile ArcGIS.Core.Data.Geodatabase at the specified path
    Syntax
    Public Overloads Shared Sub DeleteGeodatabase( _
       ByVal mobileGeodatabaseConnectionPath As MobileGeodatabaseConnectionPath _
    public static void DeleteGeodatabase(
       MobileGeodatabaseConnectionPath mobileGeodatabaseConnectionPath
    Parameters
    Exceptions
    ExceptionDescription
    The length of the local path is greater than 215 characters.
    mobileGeodatabaseConnectionPath is null.
    The input path does not contain a mobile ArcGIS.Core.Data.Geodatabase.
    A geodatabase-related exception has occurred.
    Example
    Deleting a Mobile Geodatabase
      await QueuedTask.Run(() =>
        // Create a MobileGeodatabaseConnectionPath with the name of the mobile geodatabase you wish to delete
        MobileGeodatabaseConnectionPath mobileGeodatabaseConnectionPath =
          new MobileGeodatabaseConnectionPath(new Uri(@"C:\Path-To-Mobile-Geodatabase\YourName.geodatabase"));
        // Delete the mobile geodatabase
        SchemaBuilder.DeleteGeodatabase(mobileGeodatabaseConnectionPath);
    Requirements
